Old 02-27-2014, 02:15 PM
propsync's Avatar
propsync propsync is offline
Default Can the IO540 run mogas?
I happen to run into this article today which leads me to believe pipistrel is attempting to gain lycoming certification to run certain engines on mogas.
http://www.flyingmag.com/aircraft/pi...MjYxNTg5MTU4S0
Tom B
Tampa, FL
EAA - Tampa Exec Airport
Old 02-27-2014, 02:34 PM
pierre smith's Avatar
Yes, if it's 8.5:1 compression....same cylinders and pistons as a O-360.
We used to taxi our Pawnees up to a gas station in the '70's, working off roads and buy mogas. They had the 230 horse, derated
O-540's.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 02-27-2014, 03:03 PM
propsync's Avatar
Noted, thanks!
Tom B
Tampa, FL
Old 02-27-2014, 03:56 PM
ppilotmike's Avatar
Default One other thing...
In order to do this, wouldn't you have to protect your fuel tank interiors somehow? I thought the mogas causes corrosion in the tank and lines, no?
Mike Rettig
VAF Dues Current
Old 02-27-2014, 04:13 PM
N941WR's Avatar
N941WR N941WR is offline
If the FAA approves MOGAS for aviation, it will not be the same stuff you get from the pump at your local gas station. It will more than likely be ethanol free and won?t have the other additives you get in your pump gas. Thus you will have no problems with corrosion. If corrosion is a real fear or not, I don?t know.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 02-27-2014, 04:32 PM
No if you burn it fast and do not let it sit in the tanks
Old 02-27-2014, 07:29 PM
paul330 paul330 is offline
Is the question WILL a 8.5:1 IO540 run on Mogas or is it APPROVED to run Mogas?
As I understand it, the IO540 is not approved even though it has the same compression as many 360s that ARE approved. See Lycoming SI1070. In Europe we now have unleaded Avgas (UL91 or 91/96UL) which is approved for many 540 models.
The issues with Mogas are well documented but in summary:
- it is cut with higher vapor pressure for auto use which can lead to vapor lock. The VP is not consistent and changes with the seasons.
- it us getting near impossible to obtain Mogas without significant percentages of ethanol. As you mention, ethanol can attack various components unless you make some mods. Also, there is an issue where any water in the tank tends to bond with the ethanol in preference to the gas and drop it out of solution. You therefore lose your anti-knock agent (short version!)
- The stuff you get at the gas pumps is not subject to the same quality controls as Avgas.
Having said that, I believe your experimental rules allow you to use it and I know there will be endless posts saying how wonderful it is...... And, yes, there are various ways to mitigate many of the issues. What you need is a US equivalent of our UL91 - but it's an environmental bonus and only a very small financial one.
Paul
Mercy Air, White River FAWV
RV-10 ZU-IIZ - "Zeus"
Building Bearhawk Bravo - RV-18 not available
2019 Donation Made
Old 02-27-2014, 09:46 PM
9GT's Avatar
9GT 9GT is offline
Did a 2.4 hour Phase 1 testing flight last week in my IO-540 V4A5 RV-10. Left tank 100 LL, right tank pure 90 octane ethanol free "Recreation Fuel" a local gas station started selling recently. Took off and landed on the 100 LL and put 1.8 hours on the right tank at altitude's up to 9500' msl. The engine ran great and virtually no noticeable differences showing on the engine page. The Lycoming tech guys at the Lycoming presented engine dis-assembly/re-assembly seminar at Airventure I attended a few years ago stated the engine would be very happy running mogas. Next time up I'll do some more testing but liking that the rec fuel is more than a $2 per gallon savings.
David C.
Howell, MI
Old 02-28-2014, 05:48 AM
propsync's Avatar
According to the article, it appears as pipistrel is looking for lycoming to certify the gas for use so that would be a leap.
Tom B
Tampa, FL
Old 02-28-2014, 06:37 AM
smokyray's Avatar
smokyray smokyray is offline
Default Good on em...
Tom,
I ran Non-Ethanol 91 Octane in my Harmon Rocket's 10.4:1 IO-540 C4B5 for 5 years. I currently run it in my 8.5:1 RVX. It's available all over FL and other parts of the USA. http://pure-gas.org/ Works great and is $.4.20 a gallon here. Ethanol's big issue is retaining water within the fuel, hence using Non-Ethanol.
In 25 years of MoGas RV flying, I have found it to run as well or better than 100LL with less plug fouling on the Mag side. My Electronic Ignition plugs never foul, regardless of fuel. There are lots of tips and pointers out there, I just use three.
1. Longer summer run-up (vapor lock prevention in summer)
2. Additives, Marvel Mystery oil, CD3. Optional, but work well.
3. Don't let it sit in the tanks for long periods.
It's the way of the future IMHO...
V/R
Smokey
