Thanks Greg! I feel better now that Iam walking out of the tunnel and can see light. I'll keep them supported and I am using 18 awg shielded. I bought those grounding rings with the wire attached that side up on and over the shield wire and then you use a heat gun to melt the ring. Then just a couple on ring terminals.Bought them all at STEINAIR,should be here today. I also have a Catto 3 blade prop. Do you find the 3 blade quieter than a two blade and less vibration? Mines in a box on the floor waiting for a install. Mine RV9A should be flying by Jun 30 2014. It better be!
Dave thanks for the heads up on the twin Dynons you have. I too have the DYNONS 10" & 7". That will be next to hook up. You mentioned about the noise to EMS unit. Was it that you did not (Standard wiring) have shielded mag leads to the ignition switch? or was it the EMS main wiring harness where the sensor leads came together with the ignition wires. Which wire/s did you change to shielded wire? Very informative Dave,glad you brought it up.
Dave on another note. I built a shelf between the sub panel and instrument panel right behind the Dynon 10" for the ABS-B,Transponder,EMS,, Was thinking of mounting the EMS unit up on the sub panel, and the other units on the shelf. Where did you place yours? Any suggestions for me to consider?
Ron in Oregon N421HJ
