Old 09-17-2006, 01:44 PM
avi8tor50 avi8tor50 is offline
Default Aileron pushrod rubs against pushrod hole
OK-next question-
Just finished installing the aileron pushrods in my 9A. Movement of ailerons is fine but it seems that the pushrod rubs against the aileron pushrod hole in the rear spar. Is there a bushing that is supposed to go there? Do I have an alignment problem? Bellcrank appears to be on straight. I can see some of the powder coating getting rubbed off on one side. Wonder if anyone had a similar problem.
As always, all help appreciated.
Old 09-17-2006, 02:29 PM
scard's Avatar
scard scard is offline
That hole needs to be opened up quite a bit. My understanding is that this is normal.
Scott Card
CMW E-Lift
Old 09-17-2006, 03:07 PM
Stephen Lindberg Stephen Lindberg is offline
Default Aileron stops
Have you installed the aileron stops yet? On my 7 the pushtubes rubbed on the edges of the pass through holes in the rear spar until I installed the stops. Then the fit was perfect. Another amazing pre-punch tale. BTW, I removed the aileron hinge bracket from the aileron when I installed the stops. Working only with the hinge bolted to the wing rather than the whole aileron made it much easier to fit the stops. Was a long time ago, not sure if that is in the plans, but that is how I'd recommend going about it.
Steve Lindberg
RV-7A N783Z 0-360 Hartzell
canopy skirts, panel
RV4 second owner
Old 09-18-2006, 11:58 PM
RudiGreyling's Avatar
RudiGreyling RudiGreyling is offline
Hi I had the same problem.
First check your aileron deflections as per manual, if you do not get the required deflection without it touching, then it is time to open the hole a little bit at a time.
I thought I had my hole perfect to size, but once installed it was a bit to small and the pushrod rubbed. I checked deflections and opened the hole just a little bit more.
Regards
Rudi
Rudi Greyling, South Africa, RV 'ZULU 7' Flying & RV 'ZULU 10' Flying
"Science, freedom, beauty, adventure...what more could you ask of life? Aviation offers it all" - Charles A. Lindbergh
Old 09-19-2006, 10:12 AM
Thanks to all for your help.
