02-22-2014, 11:10 PM
Homebrew Wig-Wag Controller Circuit & PCB
I?m on an ultra-slow build plan (kids in college for 6 of the project?s 9 years and counting), so I?ve indulged several low-cost homebrew projects to maintain a glacial pace.
This is an old-school electronic landing/taxi light wig-wag circuit, hacked to the highest standards of Don Lancaster?s ?CMOS Cookbook?. Completely uneconomic making this thing rather than buying, but home-built aviation not being a rational pastime in the first place, what the heck?.
The 1st picture shows the external wiring. Switch inputs J1 and J3, when grounded, each turn on a power MOSFET, providing current to the Taxi and Landing lights, respectively. Just one or both lights can be on at the same time. However, grounding the wig-wag input, J2, always causes the lights to flash alternately regardless of the state of J1 and J3.
Connections to the board are all 0.25? Fast-on tabs. Outputs J4 and J5 have on-board automotive blade-type fuses (ATC) protecting the power wires going to the lights. The power line from the bus to J6 should therefore be sized and fused for both lights operating at the same time. There may not much chance of a fault on one of the light?s supply wires that wouldn?t blow the fuse on the input power line, but that?s how I did it. I don?t expect the on-board fuses will blow very often. When was the last time you had a headlight fuse fail in your car? But if I tuck this puppy away behind the panel in a horribly inaccessible position, the fuses will no doubt blow every few days and twice on Sunday.
Optional outputs J8 and J9 are provided for indicator lights on the panel. They tee off the J4 and J5 power lines downstream of their respective fuses, so they will indicate upstream circuit problems or blown fuses. However, they operate normally in case a landing or taxi light burning out, so checking external lights remains a preflight walkaround item.
The board itself (2nd picture, showing just the top copper traces and silk screen for clarity) is 4 x 2.3 in and all through-hole components so ordinary mortals can stuff it and solder the joints by hand. There is room to shrink the layout further, but let?s just say the dimensions cater to pilot-builders with mid-20th century birthdates. Trimpot R1 sets wig-wag timing. At mid-range, wig alternates with wag over a ~2 second period (i.e, 1 second on-time, each side).
All that for about $25 in parts (small qtys) from Digi-Key, and the board was designed with a free s/w package, ?PCB Artist,? from Advanced Circuits. It was a bit more than $25 to turn the design into 5 ?bare bones? prototype boards (just the tinned copper, no solder mask or silk screen). But the durn thing worked just like it did on the breadboard, after reworking a couple of nasty solder bridges. So I went ahead with a full-spec order for 4 boards lest the DAR?some day?recoils in horror at a naked circuit.
The circuit schematic is shown in the 3rd pic. Kind of fuzzy at DR's requested 800 pixels pix width. If anyone is interested in a higher res schematic, BOM, and all that, just let me know. And if any REAL engineers on the forum see something that will cause N478PK to auger in someday, please do comment!
Kurt Haller
P-town, CA (10 min from KLVK!)
N748PK, RV-9A
Flying as of 13 July 2019
VAF dues last paid 28 Dec 2019
02-23-2014, 08:14 AM
Looking for MAX Current your circuit (and DIPs) will handle. Unable to find all the specs for the parts.
I have two 100W lights. With a low bus voltage of 12V, both draw 16 2/3 amps. (8.3333 Amps each) P=I*V or I = P/V, I=16.666667=200/12
Just looking to verify the MAX current your circuit will handle. Is the copper etch on the board capable of handling this much current?
Gary A. Sobek
NC25 RV-6 Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
02-23-2014, 08:20 AM
Anyone who quotes Don Lancaster is a true veteran of electronics design!
Thanks for sharing and contributing to the open source hardware movement.
I bet you know what a COSMAC Elf and a KIM-1 are, as well.
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 wings complete
Victoria, BC (Summer)
Chandler, Az (Winter)
02-23-2014, 08:35 AM
Looks like the power is handled by the FET's and he has a 10amp fuse inline with the lights.
02-23-2014, 10:03 AM
And no problem on the FETs for current...
http://www.irf.com/product-info/data...ta/irf4905.pdf
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
02-23-2014, 09:09 PM
Gary:
Brian's right, all the power goes through the MOSFETs. The ICs are CMOS logic (hex Schmidt trigger and two quad NANDs). The whole board draws < 1 mA when both lights are off.
The board is 1 oz/ft2 Cu and the power traces are 250 mils wide. A 16.7 A current for two 100W lights will flow through a single trace from the +14 V input pin J6 for a length just under 2" long before it splits to feed the two MOSFETs. (Half the current will flow through the rest of traces to each MOSFET, then through the fuses and off-board to the lights, so looking at this part of the power path should suffice.)
According this handy calculator, the temperature rise of the trace will be about 40 C above an ambient of 40 C. So it seems like the board will handle 100W landing and taxi lights just fine, but I have only been able to test it with two 50W halogen bulbs so far--with a power supply that sags to 10.7 V with both lights on.
Kurt Haller
N748PK, RV-9A
02-23-2014, 09:18 PM
100 W bulbs
Kurt, Monument Auto in Livermore sells 100 W bulbs, and they are amazingly cheap. I have two in my plane. If you want to try a higher current/voltage source, I can drop off my old Odyssey battery, which is still pretty good.
Leland in P-Town
02-23-2014, 09:35 PM
Thanks for the compliment, Vern, but I'm surely no design veteran.  I only know what a COMSAC Elf and a KIM-1 are because I Googled them just now.
Kurt Haller
N748PK, RV-9A
02-23-2014, 09:48 PM
Leland in P-Town
Regarding the battery, sure, why not? I'll send you a PM...thanks, Leland.
I've got plenty of 50W bulbs, so I could hook up two (or more!) in parallel for each side.
Kurt Haller
N748PK, RV-9A
03-03-2014, 09:24 PM
With Leland's "run-out" battery (didn't charge it up beforehand), numbers for two 50W halogens in series on the taxi light circuit: 7.6 A at 12.2 V = 92.7 W.
The IR4905 MOSFET on-resistance is about 20 mOhm, so it dissapates a little more than 1 Watt at 7.6 A. A calibrated finger on the MOSFET plastic package confirmed temperature just slightly above 37 C (ambient temp about 20 C). With just the one 50W halogen, there is no discernable temp rise.
Kurt Haller
N748PK, RV-9A
