  #11
Old 11-03-2007, 03:15 AM
swisseagle's Avatar
swisseagle swisseagle is offline
Default Tail-Strobe/Navlight gets very hot!
Hello Builders
I read that the strobeunit not should lay around unused for month, so I connected it to a power source and let the strobes flashing for 5 minutes.
Then I want to take it apart and store it again, but I burned my fingers on the Tail-Strobe/Navlight unit
The Wing-Strobe/Navlights get also a bit warm, but not hot. The tailunit gehts at the complete casing (which is aluminum) hot. I could bring a plasticbag to wrinkle with the tailunit, it hurt when I touched it, so I guess, it is a bit more than 60?Celsius hot.
IS THIS NORMAL?
Shop Temperature was around 20?C, the tailunit gehts the full strobe burst and the wingunits spare one.
Strobesupply is a Whelen HDACF, Tailunit a A500A-V-14, Vans Light-System 6
Thanks for any advise before I do more testing.
Regards, Dominik
Switzerland
RV-7A
Old 11-03-2007, 06:44 AM
Guy Prevost's Avatar
Guy Prevost Guy Prevost is offline
It's normal. You're dumping a lot of energy into those flashtubes. A small part of that energy kicks off some photons and creates light. The rest is just heat.
Guy Prevost
Albuquerque, NM
RV-8a Built, Enjoyed, Sold
Two Kids: Built, Enjoying
RV-10, Bought, Rebuilt, Enjoying
Build / First Flight Video: http://www.youtube.com/watch?v=8f9HXzZT1dE
Build Log: http://websites.expercraft.com/geprevo/
Arguing on the internet is like having a competition to see who can hit a brick wall the hardest. You may win, but you're still an idiot.
Old 11-04-2007, 02:01 PM
swisseagle's Avatar
Default Thanks!
Thanks Guy and Tonny for the informations!
Regards, Dominik
Old 11-09-2007, 08:31 AM
Daver Daver is offline
Default strobe heat
I'm prepping my wing tips by installing nav & strobe lights.
I bench tested the wing tip lights and, WOW, does the strobe get hot.
I'm worried about damaging the plexiglass lens with the heat.
Has anybody had this issue? Will the heat damage anything? Should I provide some sort of ventilation (small holes)?
Thanks in advance for any input!
Dave
finishing up RV9 wings
Old 11-09-2007, 11:35 AM
IowaRV9Dreamer's Avatar
IowaRV9Dreamer IowaRV9Dreamer is offline
I saw some RVs at OSH that had the strobe tubes mounted close to the lens, and you are right - the heat distorted the lens.
I'm going to find a way to keep the tube in the center of the tip - as far from the lens as possible.
Good luck,
dave
Dave Gribble VAF #232
Building RV-9A N149DG (slider, IO-320, IFR)
Restored and Flying Beech Super III N3698Q
Marion IA
Struggling with fiberglass
There is no sport equal to that which aviators enjoy while being carried through the air on great white wings." Wilbur Wright, 1905
Old 11-09-2007, 01:22 PM
Rupester Rupester is offline
Dave,
What kinduv nav/strobes do you have? I've been looking the Aeroflash units (156-0039) and have not ordered yet 'cause I was unsure how they would fit .. clearance to the lens is one of my concerns.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 11-09-2007, 01:54 PM
Default hot strobes
I'm piecing together a lighting system.
The strobes are from "Strobes n More".
The nav light is an LED cluster I found on the internet (very bright).
I searched "hot strobes" and came up with some threads that basically acknowledge the heat problem but I didn't find a solution suggestion.
The strobe power supply has a "low power" setting. Maybe I should use it.
Also I plugged the tube directly into the power supply. Maybe 15' feet of cable will reduce the voltage some.
I thought about drilling some some holes in the bottom area of the lens and a single hole at the top. I was thinking I could get some cooling air through there and also provide drain holes for inadvertant moisture.
I'll just have to think about this....
Dave
Old 11-09-2007, 01:59 PM
I recall ne of the earlier threads about hot strobes advised not to plug directly into a power supply ... said to always assure you have some length of wire in there as it does lessen the overheating.
Terry Ruprecht
Old 01-13-2008, 06:25 PM
Ron B. Ron B. is online now
What do you do,when you have a power supply in the wing tip, so as not to have electrical interference? The supply wire cannot be long.
Ron
