Old 02-22-2014, 05:46 PM
bret's Avatar
bret bret is offline
Default HS SB Finished!
I am glad I did this mod, thanks to Vans Aircraft for identifying a possible problem here and giving us a rather simple fix!
Old 02-22-2014, 05:54 PM
blueflyer's Avatar
blueflyer blueflyer is offline
looking good. after seeing you do yours, now I'm back to thinking I will do mine.....
Old 02-22-2014, 09:18 PM
Bevan Bevan is offline
Bret,
could you post a picture of the other side of the spar?
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 02-23-2014, 04:46 AM
bret's Avatar
Originally Posted by Bevan View Post
Bret,
Bevan
This was before reinstalling HS 404 and HS 405. I remeved 13 rivets in on each end, each side of the rear spar for more room to use a straight cup set.
Old 02-23-2014, 05:35 AM
pa38112 pa38112 is offline
How long did it take start to re-installed?
http://aprs.fi/N153MC
2004 RV6A Flying
2002 RV6A Flying
1978 PA38-112
Old 02-23-2014, 05:53 AM
bret's Avatar
My HS was not on the plane, took around 23 Hours. Hard to tell with all foot ball and BEER being drank Just kidding, inside joke from another thread
Old 02-23-2014, 05:54 AM
plehrke's Avatar
plehrke plehrke is offline
Looks like you can get to all the rivets with a sneezer. So can you do the entire mod alone or need someone to help buck rivets?
Philip
RV-6A - 14+ years, 900+ hours
Based at 1H0 (Creve Coeur)
Paid dues yearly since 2007
Old 02-23-2014, 08:47 AM
bret's Avatar
I had my son buck the outer ones.
Old 02-23-2014, 07:18 PM
Smilin' Jack Smilin' Jack is offline
Bret, I too finished mine today, yours looks a little easier since you lifted up so much skin to make access.
I noticed that you like me do not have the nice rivet spacing that Van's drawing shows, mine looks identical to yours.
Now to get the rivets touched up.
Will post pictures tomorrow.
Jack
Smilin' Jack & Anita Hunt
N507H RV7, KJZP Jasper, GA
EAA690
APRS/ WB4JKY
Retired Corporate Pilot CFI-AI, MEL
CE500, LRJT, HS25, C650, SBJT, CL60
Hunt Aviation, LLC.
Pilot Service, IPC's Biennials.
Comm Glider
Old 02-24-2014, 08:45 AM
akarmy's Avatar
akarmy akarmy is offline
Default Completed SB
I too completed the HS SB this weekend. Took 8 hours from start to finish over 2 days. Made somewhat easier as I don't have any paint on it and had not mounted it. The best assistive device was making some v-blocks to hold it upright. I used those for most of it including the drilling of the angle rivets and the riveting of the doubler.
Added the notches per the bulletin. I had no notches during the initial build.
Tapering the spar flanges was fun! Glad Vans gave us the tip to use the stainless sheet in-between the layers of skin. Was fairly easy with a dremel tool.
All Done!
Andy Karmy
Covington WA
RV-8 - Flying!
RV-9A - sold
Dec 2019 Paid
