Old 02-22-2014, 12:33 PM
Hotscam Hotscam is offline
Default Single failure stops both ignition systems.
Sorry got it wrong
Jack Netherlands
PH-SEP and PH-SES
RV12 #120519 and #120790
Hobbs 700+ hours and 400+ hours
Dual SV1000 Skyview 15, Pocket FMS and Powerflarm 6.0 (ADSB)
RV10 PH-USN Hobbs 350 hours
Old 02-22-2014, 12:57 PM
hufise hufise is offline
Default Purple wire
Hi j?ri
The purple wires are connected to the starter relay contact
This is for the easy start procedure
Do not put it on ground
Gr?sse Daniel
Schweiz
25 flight hrs
First check Donne
