Originally Posted by Rick6a
As a technical counselor, I always try to acquaint the builder to the many benefits of referring to a drill index chart. Just yesterday, a builder stopped by my hangar to borrow a reamer and asked what size drill bit he should prepare the hole with. I encouraged him to tape a drill index chart on a wall in his shop and refer to it often.
A #40 drill (or #41) drill bit is standard for preparing a hole to accept an AD3 rivet. But your question is just scratching the surface. You are going to run into many situations in which you must figure out what the hole diameter for a given fastener will be. You can quickly determine that with two tools. One is a drill index chart. The other is a micrometer or dial calipers. The two tools go hand in hand. If you seek optimum hole quality, use em.
...the micrometer if you buy one of these. Made by General tools and in most good hardware stores -
http://www.generaltools.com/Products...o-60)__15.aspx
If you want to know what drill to use for your rivet/screw, just poke the rivet/screw through the holes in the gauge...
It also helps you check that the drill you just picked up for the #8 screw clearance hole is really a #19 and not the #21 you bought to drill stock for a 10-32 tapped hole...
It also helps you skip the tap drill chart previously mentioned since it is engraved right on the face of the gauge.
PS The micrometer is still good to have, but the "hole gauge" is probably easier for drill bits, even if it is a bit lower-tech than the 6 digit precision of Rick's micrometer.
In this case, simpler is better....
