Old 02-21-2014, 07:50 AM
Arlen's Avatar
Arlen Arlen is offline
Default How is the Koger Sunshade attached?
...in an RV-6 slider, how does the aluminum frame of the Koger attach to the canopy? I can't find the answer on their web site.
Arlen
Donation to VAF 10.29.18
RV-6, February '14, SOLD December '15
Old 02-21-2014, 08:20 AM
krw5927 krw5927 is offline
I have the extended Koger shade for sliders in my 9A. There are four small holes that get drilled and tapped for machine screws in the top center slider frame member. I think they're 6-32 screws, but they might be 4-40. It's been a while so I don't remember for sure. The track has corresponding holes and is held to the frame with the screws.
With the standard shorter version of the Koger shade there may be fewer screws/holes that have to be installed.
It's pretty easy to do, but make sure to use a good quality tap and plenty of lubricant as always. The tap is so small it's easy to break off. Ask me how I know.
From Rosie: Concur, that's how mine was attached. Using tape for anything here in the desert temps is a losing battle but you are probably OK with tape in FL if desired
Kurt W.
RV9A
FLYING!!!
Old 02-21-2014, 10:24 AM
blueflyer's Avatar
blueflyer blueflyer is offline
the frame of my non-RV style Koger sunshade has 3M adhesive pads along the rail that stick the rail to the canopy. No drilling was required to install mine.
Old 02-21-2014, 12:02 PM
scard's Avatar
scard scard is offline
for the tip-up, it is attached with double sided tape. Works well.
Scott Card
CMW E-Lift
Old 02-21-2014, 01:48 PM
walkman's Avatar
walkman walkman is offline
Default Hi Arlen
Nice avatar, looks familiar.
Guess I need to change my signature
RV-8 IO-360 (Bought)
RV-6 O-360 C/S (Sold)
Walkman aka Flame Out
Old 02-21-2014, 04:13 PM
Arlen's Avatar
Yessir! How 'bout that!
Arlen
