Old 02-20-2014, 09:13 AM
flyingriki's Avatar
flyingriki flyingriki is offline
Default Parts Overhaul Shops
Have my engine all apart and cleaned up. Seems to be in pretty good shape after 2300 SMOH. Am deciding between shops to send out the cases and rotating parts for inspection and machining as necessary.
What are your experiences and thoughts on the various shops that do this work? Am looking at Divco, Aircraft Specialty Services, Nickson, Romans, ECi - any others? So far talked to mainly salesmen and none have a lot of input on modifications other than pricing. If you've used one of these and are pleased with their work who was your contact?
Thank you!!
Old 02-20-2014, 03:18 PM
osxuser's Avatar
osxuser osxuser is offline
http://www.chuckneyent.com/
The inventor of the Ney Nozzle. I've talked to him a few times, he will be getting my case next time around. Crank will go to Aircraft Specialties most likely.
RV4 wing in Jig @ KPOC
RV7 emp built
Old 02-20-2014, 04:23 PM
rhill rhill is offline
Default CrankCase Services
Check out Crank Case Services in Sand Springs,Ok
