Pulling Impulse Coupling on Slick Mag
I am doing a tear down / inspection on the Slick Mags on the O-320 that I am rebuilding. I need to pull the impulse coupling, but do not have the special tool. I am thinking that I should only pull from the main shaft where the slot for their puller is, but don't have a puller that small. I could probably get a puller on the larger section, but fear it may not be strong enough.
I was thinking that a bearing seperator may get in the that groove and I can rent one from Autozone.
Has anyone done this without the special puller?
Larry
