Old 02-19-2014, 10:40 AM
jchang10 jchang10 is offline
Default Push-pull cable lost detents
http://vansaircraft.com/cgi-bin/stor...product=bowden
I have a push pull cable (CT A-740) cable that has lots its detents for some reason. Has anyone dealt with this before or should i just order a new cable?
Thanks!
Jae
#40533 RV-10 Builder and CFI
1/2006 Started build
10/19/2011 First flight
Old 02-19-2014, 10:59 AM
vic syracuse vic syracuse is offline
Super Moderator
Default Yes
Yes, they wear out. Sometimes you can fix it with some safety wire if it is NOT for a critical application, like the mixture.
But it's easiest to just replace.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
Old 02-19-2014, 11:08 AM
Default English grammar can count sometimes
Vic,
Did you mean to have that last comma there?
I think the mixture is critical (no comma).
Old 02-19-2014, 11:12 AM
comfortcat's Avatar
comfortcat comfortcat is offline
Originally Posted by BobTurner View Post
Vic,
Critical punctuation?
"Let's eat Grandma"
"Let's eat, Grandma"
CC
David Boeshaar
RV-9A - N18TD (reserved) - Fuselage.
"My greatest fear: What if the hokey pokey really IS what its all about?"
TDAircraft.com
-July-
Old 02-19-2014, 11:59 AM
It is actually for the alternate air cable, so it would be strange for it to wear out since it's not really used. However, it is critical since it needs to stay closed, and right now, it won't.
I have the same cable for the cabin heat, which i constantly use, which are fine. I think the alt air cable must have failed somehow or was defective.
Oh well, i think ordering a new cable is probably easier in the long run.
Thanks!
Jae
Old 03-23-2014, 12:31 PM
In conclusion, i finally got around to it. There is a small spring around the cable housing which is supposed to hold tension in the cable grooves. The spring seems to have lost its strength somehow and won't hold enough tension in the groove, allowing the cable to slide past.
My solution was to run a tie-warp inside the spring. Increasing the diameter of the spring puts more load on the spring which seems to have been enough to hold the groove again.
That's it. Thanks for the help.
Jae
