Old 02-19-2014, 08:59 AM
Bayou Bert's Avatar
Bayou Bert Bayou Bert is offline
Default Skyradar D2 External Antennas
I would like to get two monopole antennas for my D2, just like the
transponder antenna but different lengths.
The D2 receives on 978 and 1090MHz. So the halve wave lengths would
be 6.03 and 5.41 inches. Half of that for quarter wave, which most transponder antennas appear to be.
So if someone know where I can get the parts or someone that makes
them I sure would appreciate the direction.
I want to put them on the belly just behind the baggage area on my 9A.
Radenna says they can be up to 8' from the receiver or more with use of
a good quality coax. They are receive only so little more than a 1' apart
should work good.
Direction, comments appreciated.
Bert
RV-9A ?Pearl?
Working on Instrument ticket
Donation Done for 2020
Old 02-19-2014, 09:33 AM
Tumper's Avatar
Tumper Tumper is offline
Default Stein Air
Contact Stein Air, they fixed me up.
I'm not flying yet but they set me up with the antennas.
Dean Eiland
Aubrey, TX
Former Vice President EAA Chapter 1246
RV-9 (yes) N369RV
Mattituck IO-360, C/S Whirl Wind Prop, GRT, Digiflight II, Garmin SL30 & GTX 330 and Hotel Whisky Aux tanks, Bla Bla Bla
Flying
Old 02-19-2014, 09:35 AM
AllThumbs's Avatar
AllThumbs AllThumbs is offline
I'm sure, considering the VF fan base, an actual radio engineer will reply but I believe the ADS-B ground stations use vertically polarized antennas. My little home-made 1/4 wave picked up stations over 100 NM away. I've also heard you can just use a plain old transponder ball-whip antenna (1090) and it'll pick up 978. Since you're not transmitting on 978 the higher-SWR is not much of an issue.
You can just try it in a temporary mount inside the plane next to a window (canopy) and see what you get before you punch holes in the plane. Search for forums for external stratus antenna if you want to see a cheap 1/4 wave I built. PM me if you want build one and I'll help you find the parts.
RV-6 panel is fine. Just... fine.
2019 VAF dues paid!
Old 02-19-2014, 09:44 AM
RV8iator's Avatar
RV8iator RV8iator is offline
I put two regular transponder stick antennas on the left wing fairing just behind the gear leg and they work like a champ with my SkyRadar D2
Jerry "Widget" Morris
RV 8, N8JL, 3,000+ hours on my 8.
VAF #818
Saint Simons Island, GA. KSSI
PIF 2008, 2009, 2010, 2011,2012, 2013, 2014, 2015, 2016, 2017, 2018, 2019, 2020
I just wish I could afford to live the way I do
Old 02-19-2014, 10:36 AM
Bayou Bert's Avatar
Default Great
Thanks Jerry, that's what I was hoping to see.
Someone who had done it. Being a ham, I couldn't help
but try to get them on the exact frequency, but if the
xpond ant work..fantastic.
My transponder ant is centered about 6" aft of FW, is yours close
to your D2 ant?
Thanks much
Bert
RV-9A ?Pearl?
Old 02-19-2014, 10:49 AM
Bavafa Bavafa is online now
Plus one here. I can pickup stations while on the ground. Same location for the antennas.
http://deltapopaviation.com/UAT_Antenna.html
here is where I got my antennas and they are great.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 02-19-2014, 11:03 AM
SkyRadar recommends using a DME antenna for 978, a transponder antenna for 1090 MHz.
I found some inexpensive 50 ohm coax with SMA connectors (male one end, female the other) on the internet and just extended the built in antennas up to my fiberglass door posts (RV10), where they are taped on. I have not yet done any extensive testing but they do work locally.
Old 02-19-2014, 12:40 PM
RV8iator's Avatar
to your D2 ant?
Thanks much
My transponder antennae is about 8 inches left of centerline about even with rear stick position on an 8.
VAF #818
