Old 02-18-2014, 12:56 AM
PerfTech's Avatar
PerfTech PerfTech is online now
Talking H/S Spar Mod Slide Show from A.S.A Now Up!!!
... We now have parts available and a small slide show up for viewing on our website, http://antisplataero.com/Videos.html showing the fix we have created for the H/S spar crack issue. The slide show also gives some basic information as to installation and what is involved to compare with the other method that is available. This mod is somewhat less intrusive, and for that reason may appeal to many. If you like what you see and want more information just give us a call. Thanks, Allan...
Allan Nimmo
AntiSplatAero.com
Innovative Aircraft Safety
Products, Tools & Services
Info@AntiSplatAero.com
Southern California (KREI)
RV-9A / Edge-540
(909) 824-1020
Old 02-18-2014, 03:23 AM
rhill rhill is offline
Allen, I have a problem getting any audio on the slide show,volume is way too low,so I missed the explanation on why there is no finger extending to the top and bottom of the rib flange?
Old 02-18-2014, 05:06 AM
noelf noelf is offline
Same here. Audio is way to low for my iPad.
Noel
RV-6A N6NF
tip-up
flying
Old 02-18-2014, 05:46 AM
Steve Ashby's Avatar
Steve Ashby Steve Ashby is offline
Default Any data?
Can we get some engineering data that shows this fix is at least as good as the one Vans has approved? I know stainless steel is stronger than aluminum, but I would sure like to see some of that element analysis mojo to show the spar will be stronger and that this particular patch will prevent crack propagation and spar failure.
Steve Ashby
Stone Mountain, GA
N184RW (reserved)
RV-8A
YIO-360 180 hp Lycoming
Hartzell Blended Airfoil Prop
Engine Hung
Old 02-18-2014, 10:09 AM
PerfTech's Avatar
Red face Audio Problem
....Sorry Guys!!!!
Something must have gone crazy when it was uploaded. I will have my computer whiz address this as soon as he comes in today. Again "Sorry for this issue". Thanks, Allan...
Allan Nimmo
AntiSplatAero.com
RV-9A / Edge-540
(909) 824-1020
skyking902001's Avatar
skyking902001 skyking902001 is offline
Default Cost?
Watched the vid, but couldn't find a price for the mod.
Steve Riffe
RV-8
N23SR
Dues paid to 12-1-20
www.mykitlog.com/skyking90200
Old 02-18-2014, 10:47 AM
DanBaier's Avatar
DanBaier DanBaier is offline
Maybe it's me - the recording volume seems so low that on playback it's pretty much impossible to hear what's being said during the presentation.
Dan
RV7A (N7101) - Flying 10/2008
CFI- SE/ME/Inst
A&P
KC2ZEL
Old 02-18-2014, 10:55 AM
Vern's Avatar
Vern Vern is offline
Default Audio
I listened to it my Mac and the audio was fine.
Would also like so engineering type data that this fix is equal to or better than Van's.
To my untrained eye, it looks good and is very creative.
Vern Darley
Awarded FAA "The Wright Brothers 'Master Pilot' Award"- for 50 years safe flying
RV-6A N680V / RV-10QB N353RV
Luscombe 8E N2423K 50+years
Hatz Biplane N2423Z soon to be birthed
Falcon RV Squadron Founder
KFFC Hanger D-30
Peachtree City, Ga
770 310-7169
EAA Technical Counselor #5142
EAA Flight Advisor #486336
ATP/CFI/A&P/DAR
Old 02-18-2014, 11:05 AM
DanBaier's Avatar
Well - tried it on two PCs and on a iPad and the result is the same. Lead in music is fine, the voice over is muted to the point of not being able to hear it.
Dan
CFI- SE/ME/Inst
A&P
KC2ZEL
Old 02-18-2014, 11:15 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
I heard it, but had to go to max volume on the computer.
Here is my $0.02
To me as a non engineer type, the mod looks good------I like the fact you can still see the area where the cracks are occurring in the spar, so you can monitor the condition of things.
Looks to be much easier to install that the factory setup, but as has others folks have mentioned, is there any data to verify the setup?
If I had a plane subject to this SB, I would most likely install this as a preventive measure if there were no existing cracks-----and the factory setup is there were existing cracks.
Good job Allan.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
