Old 02-16-2014, 11:02 AM
Flying again!'s Avatar
Flying again! Flying again! is offline
Default Suggestions on oil leak from pushrod seals
I had oil leaking from the pushrod shrouds on cylinders 3 & 5 on my O-540. I replaced them and no leaks for about 6 hours.
I have oil leaking from the o-ring seal at the head side of the cylinders, all 4 that I replaced. I made sure the area the seal fits in was clean with no grunge that could cause a bad seal.
I am wondering if it is a weak push rod tube seal spring. I thought I saw mention of a Lycoming SB that recommended using 2 springs to ensure sufficient compression.
Any thoughts or suggestions are welcome!
RV-10 N331JH 3rd owner (First flew in 2005, #15 flying)
Northwest Regional 52F
Old 02-16-2014, 01:42 PM
131RB 131RB is offline
I am curious if you are pushing them in far enough. The O ring needs to be seated inside the cylinder not just against it. You sometimes have to seat them by hand prior to installing the spring keepers.
Ryan
Old 02-16-2014, 02:26 PM
Good point Ryan.
I pushed them in by hand until they "popped" in and the lower green seals had expanded. Couldn't push them in any further. That is why I am wondering if the springs are too weak.
Old 02-16-2014, 04:52 PM
N941WR's Avatar
N941WR N941WR is offline
Did you use ECi clips? They had a bunch that cracked, allowing the tubes to leak.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 02-16-2014, 05:24 PM
esco esco is offline
Default close inspection
my O-320 pushrod shroud tubes leaked, not the seals.
Close inspection identified #2 tube was out of round at the case end, and was resolved by use of flaring tool; the dent on the bottom (adjacent to cooling fins) of #4 tube was not identified until I removed the tube completely.
Good luck!
______
VAF dues paid though exempt
RV-9A sold (I miss that bird!)
RV10 sold (miss that one too!)
RV-14A build underway
Old 02-16-2014, 06:56 PM
No ECI clips. I looked at them and they were not cracked. Thanks for the suggestion!
Old 02-16-2014, 06:59 PM
Good luck!
Guess I know what I will be doing this next weekend, pulling the tubes. Still wonder if I should change the springs....
Old 02-16-2014, 09:45 PM
Shoot me a pm and I will give you my phone. I think this is an easy fix.
Ryan
Old 02-17-2014, 04:10 AM
Ryan
PM sent - Thanks
Old 04-02-2014, 08:55 AM
Titan-Xpert's Avatar
Titan-Xpert Titan-Xpert is offline
Some times a washer is installed under the spring clip; it tends to reduce the spring pressure. If you have these washers installed remove them. Inspect the spring clip it should not be flat. Inspect the area that the O-ring sets in the head for scratches, gouges. Polish if necessary with fine scotch brite pad. Inspect area of pushrod tube where the O-ring sets, some times this area is painted the paint can chip crack or peel. Paint should be removed from the o-ring groove and polished with fine scotch brite. When installing new seals they should be lubricated before installation, I prefer isopropyl alcohol.
On the older style narrow deck Lycoming pushrod tubes, they required two flat steel springs about .020? thick with a single washer under the springs .The newer style uses a single stamped spring about .030 to.035?thick, it is not flat, it has a lip on each end. It should not have a washer under it.
I hope this helps with your problem.
Bobby Looper
Titan Expert-Customer Support
Email Titan Support
Continental Motors Inc.
