Old 02-16-2014, 08:29 AM
comfortcat's Avatar
comfortcat comfortcat is offline
Default Panel punch thickness....
I have a three part panel from Affordable Panels that is .085 (.086?) and I was wondering if I can use a panel punch on that thickness? I'm cutting the left side but will send the right out for cutting.
Dkb
David Boeshaar
RV-9A - N18TD (reserved) - Fuselage.
"My greatest fear: What if the hokey pokey really IS what its all about?"
TDAircraft.com
-July-
Old 02-16-2014, 09:32 AM
bruceh's Avatar
bruceh bruceh is offline
Should be no problem using a punch on that thickness. Lube helps!
Bruce Hill
2020 VAF donator
Old 02-16-2014, 09:37 AM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
Yes, but it is a bit of effort.
I found that cutting about half way through, then rotating the punch 90* helped a lot, the punch cuts better at the beginning of a cut.
For sure lube the threads on the center bolt.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 02-16-2014, 06:23 PM
Charles in SC Charles in SC is offline
I used a panel punch on mine but found that squeezing it with a hydrolic press was a much better way to go.
RV 7
