Go Back   VAF Forums > RV Firewall Forward Section > Electronic Ignition Systems
Old 02-15-2014, 10:13 PM
bill@fusion4.net's Avatar
bill@fusion4.net bill@fusion4.net is offline
Unhappy How to run sensor wires from Lightspeed mini-sensor back to firewall
I am having a hard time trying to figure out how to route (and securely attach) the sensor wires that go up to under the flywheel.
Does anyone have some pictures of how they routed the wire from under the flywheel back to the oil pan? Or did you go over the engine?
The wire is attached to the sensor, so to go through the baffling would require some large holes.
I have spent the last 6 hrs trying different routings, and I am not happy with any of them.
Bill Thomasson
RV-10 - Flying - Phase II. 99.8% done... it's never really done!
http://sites.google.com/a/fusion4.net/rv10/
Suwanee, GA.
Old 02-16-2014, 06:03 AM
bhester's Avatar
bhester bhester is offline
Thumbs up How about this!
Bottom of the page:
http://home.newwavecomm.net/bobbyhester/2012Flying.htm
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2019 VAF donator - alot better than any magazine subscription
Old 02-16-2014, 06:58 AM
WAM120RV WAM120RV is offline
Default Over the top.
Hi
There is a photo on my blog under Engine prep before big start up four pages back in the older posts. I routed mine over the top secure by three p clips, then out through the rear baffle, along the engine mount to the firewall. It keeps the wiring runs shorter.
http://www.aerobuilder.blogspot.com
Steve Arnold
England
In completion stage of Loehle P5151
Built and now Flying G.BVLR Vans RV4
Rebuilt G.BDBD Tailwind
Rebuilt G BVTN Kitfox
Built G CDCD RV9A with WAM120
Riveted wings on Glastar G.LEZZ Now (G. SKUA)
Old 02-17-2014, 06:22 AM
YellowPeril's Avatar
YellowPeril YellowPeril is offline
Routed mine underneath the #2 and #4 cylinders. I slit a piece of thick-walled tubing and secured around the wires where they got near the flywheel as an anti-chafe guard.
1100 hours and running without a hitch (there anyways).
Nick "Hairball" Knobil
RV8 N80549 (First Flight 2003)
Aerosport O-360A1A, Dual LS CDIs, WW200C
Bowdoinham, Maine
Old 02-17-2014, 09:30 AM
Rupester Rupester is offline
Mine are routed/installed same as Nick's ... below cyls 2 & 4, but above the intake tubes.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 03-07-2014, 09:50 PM
deek deek is offline
On my LongEZ over the top >>
'83 LongEZ - N888EZ 3,671 hours
'89 LimoEZ - N26EZ 686 hours (sold)
A couple of Glasairs and a Lancair 320...
Next: a RV14 need something to build
