Old 02-15-2014, 02:55 PM
aparchment's Avatar
aparchment aparchment is offline
Default Wheel bearing disassembly question
Is there an easy way to take the wheel bearing itself apart? I got some metal shavings on it and want to completely disassemble it for cleaning.
I have the bearings out of the wheel hub now I need to get the race (I think it's called) separated from the metal part that surrounds the axel. There must be some trick to move the cylindrical rollers out of the way so that the part that rides on the axel can slide by.
Antony
RV-7A
Empenage complete, wings complete, tip-up canopy complete, starting wiring ...
Old 02-15-2014, 03:12 PM
Mark Burns's Avatar
Mark Burns Mark Burns is offline
Default Nope, that's as far as it comes apart
The tapered roller bearing consists of a 'Cone" and a "Cup".
i.e. inner and outer races. The outer race is a press fit in the wheel.
The inner race or "cone" has the race, roller separator and rollers.
These are not disassembled in the field. Or anywhere else for that matter
So, to clean it just slosh it around in mineral spirits.
Don't spin it with compressed air as you could damage it.
Hope this helps,
Mark
Mark Burns
Ruston, Louisiana
RV-7A N781CM 1,650+ hrs
FFI FL-24
A&P
Old 02-15-2014, 06:21 PM
aparchment's Avatar
Default Thanks
Thanks Mark!
Antony
RV-7A
Old 02-15-2014, 06:32 PM
Norman CYYJ Norman CYYJ is offline
If you have metal shavings in the wheel bearing it is time to buy new bearings and replace them, repack with good wheel bearing grease and reinstall, go flying and enjoy.
Old 02-15-2014, 07:22 PM
rhill rhill is offline
Default Don't forget to change the race
Don't forget to get a brass drift pin and drive out the old race and replace it also.You can use the old race as a driver over the new race and a block of wood to bang on.
Old 02-15-2014, 07:57 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Change to the sealed bearing mod and Forget about it... absolute dream mod!!!!
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 02-15-2014, 08:53 PM
Rick_A's Avatar
Rick_A Rick_A is offline
What's the sealed bearing mod? Is there one for Grove Wheels?
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
Old 02-16-2014, 07:54 AM
Larco's Avatar
Larco Larco is offline
I think Reiley might be referring to this: http://www.antisplataero.com/Nose_Wh...aring_Mod.html
Old 02-16-2014, 09:50 AM
They do nose and mains... had them all done. Awesome!
Reiley
VAF# 671
Friend of the RV-1
Old 02-16-2014, 12:45 PM
Larco's Avatar
I goofed on the web address. It should work now
