02-13-2014, 04:48 PM
Master and Starter Solenoids
I have noticed a couple different orientations on these devices. Is there a preferred veritcal orientation (which way is "up") on each of these. Thanks
02-13-2014, 05:03 PM
I really don't think it matters with the Starter solenoid.
On the master:
The master you ground to cause it to close. That said, the battery cable must be on one particular side of the solenoid. I don't think this will matter on the starter solenoid. On it, you must provide the voltage to close the contactor.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
02-13-2014, 05:31 PM
Starter Soleniod and ACRO
There were some people who had the starter engage while doing positive G. So they mount them sideways.
Horse Power is good, more is better and
Too Much is Just Right
RV 8 Super charged Barrett IO-390
Dues paid 2020
Dan "Nordo" West
02-13-2014, 05:33 PM
I understand the "hook up" electrical concept. The question was directed to the physical arrangement regarding mounting. I had heard comments of because of the way the solenoid moves (master), that it had to be orientated in a particular matter for the contacts to function optimally?
Thanks Dan
02-13-2014, 05:34 PM
I could see that. I dissected one that I thought had failed. The spring was not that stout. I would think contactor portion on bottom would address that issue. The contactor portion is the part where the leads connect.
Alton DeWeese
N4IDH
Construction Log
?Mark Twain
02-13-2014, 05:39 PM
Thanks Alton
02-13-2014, 07:06 PM
EAA taught me that.
Took one of those two day electrical coarses a couple of years ago near Boston in a SportAir EAA workshop and that's exactly how they taught us to mount the starter solenoid. If your going to do a lot of high G stuff it sounded like a good idea. Even if the solenoid engaged for a second it would be bad.
Tom Norwood
Classic "Short Tail 6A N822PM
TMX-O360. Phase 1
02-13-2014, 10:35 PM
Don't Van's instructions/schematics have it mounted "upside down" for that reason? That's how I did mine...
See DWG 31A.
02-14-2014, 08:08 AM
The old theory was that you wanted gravity to help pull the master closed and the starter open in the event of a dead spring. So.... Starter contacts down and master contacts up. That's their story and I'm sticking to it.
Actual repeat offender.
