Old 02-12-2014, 07:47 AM
lr172 lr172 is offline
Default Fuel Injection Height vs Carb
I am putting an O-320 in my RV-6A, but have an O-360 cowl. I understand this cowl is a little taller to accommodate the taller Fuel Injection body. Does anyone know the standard height of the Fuel Injection throttle body? I am trying to order materials to make a spacer in advance of getting all this mounted.
I was originally thinking of making the spacer (between carb and air box) with 2024 stock, but have been thinking about some Micarta (Phenolic) stock that I have. This is rated to 250* continuous, which would seem to work. I can't imagine the sump getting much hotter than 250 for an extended period. I would use alum spacers to insure that I have torque on the attachment nuts. I would welcome thoughts here as well.
Larry
Old 02-12-2014, 01:13 PM
cajunwings cajunwings is online now
Default Servo Height
Just measured my Bendix RSA-5AD1 and it is 5.50".
Don B
RV 9 Rebuild in Progress
IO-320
Old 02-12-2014, 02:24 PM
Thanks for checking that, I appreciate it. For those following this, that is about a little less than 7/8" taller than the MA-4 carb height.
Larry
Old 02-12-2014, 03:49 PM
jdeas's Avatar
jdeas jdeas is offline
Default FAB extension
I built an extension to make up the space and spread the load out on the FAB box to reduce the cracking problems on the FAB.
Didn't use it as I ended up with an IO-360.
Send me a PM if you want the drawing or are interested in being the new owner of this paperweight. (height ~ 1.1" )
JD
RV-7 N314SY (KWHP)
IO-360-B1B
CANbus based trim/flaps and electrical
Old 02-12-2014, 04:01 PM
N941WR's Avatar
N941WR N941WR is offline
Just modify the FAB.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 02-12-2014, 07:54 PM
Ralph Inkster Ralph Inkster is offline
Seems every time I'm doing the FAB air box's I am modifying the inlet angle up to align with the cowl inlet. Maybe you should wait till you've fit the cowling, much easier realigning down than up.
Ralph
built a few RVs, rebuilt a few more, hot rodded some, & maintained/updated a bunch more
