Old 02-12-2014, 07:08 AM
Tooch Tooch is offline
Default Gear in accessory case
I just took off my vacuum pump from the accessory case on my O-360. Just wondering if it is ok to remove the gear that is in there and leave it out for good before putting on the new cover plate?
Thanks for any help,
Matt
Old 02-12-2014, 08:07 AM
aerhed aerhed is offline
Either leave the gear in or remove the adapter housing and gear. Don't leave the adapter on without a gear.
Actual repeat offender.
Old 02-12-2014, 08:19 AM
Default Adapter housing
What would happen if I left the adapter housing on without the gear?
Old 02-12-2014, 09:14 AM
There's an oil hole to lube the gear drilled in the adapter. No gear means pressure oil squirting into the empty shaft hole.
Old 02-12-2014, 11:20 AM
Default Blow out
Will it find its way out the breather tube or where does the oil go because I have noticed way more oil on the belly after flight
Old 02-12-2014, 05:12 PM
It will result in some loss of oil pressure and volume to the engine guts and will drain out of the shaft hole. Might get whipped around by the cam and mag gears and out the breather.
Old 02-12-2014, 06:27 PM
Default Thanks
Thanks for your help
