11-26-2016, 10:15 AM
Lower longeron to firewall bolts.
When I fitted the specified AN3-5A bolts they seemed a little long. When I threaded the nut on with only one washer, 4 threads were visible leading to a danger that the nut was tightening on the shank of the bolt, so I added a washer. Unfortunately, I decided to add it under the bolt head. I torqued everything down, but now that I am riveting I have realised that these will interfere with good access to buck these important rivets. So unfortunately they have had to be removed. If I had put the extra washer under the nut I might have still had good access. IMG_0956 by Ed Fleming, on Flickr IMG_0947 by Ed Fleming, on Flickr IMG_0947 by Ed Fleming, on Flickr IMG_0947 by Ed Fleming, on Flickr
Ed Fleming
RV-7- Nearly there!
Harare, Zimbabwe
Reason: fix photo links
11-26-2016, 10:24 AM
Firewall sealing
I used 3m Firebarrier 2000+ to seal the firewall. Vans won't ship their stuff outside the lower 48, so not even to Alaska where I can pick it up on my travels. 3m costs 20 bucks at ACS and they'll ship it anywhere. This stuff was recommended by Dave Prizio in his "best practices" column. It is silicon based and comes in a large tube that can be loaded in a caulking gun. No mixing required, very easy to apply IMG_0940 by Ed Fleming, on Flickr IMG_0940 by Ed Fleming, on Flickr IMG_0940 by Ed Fleming, on Flickr IMG_0940 by Ed Fleming, on Flickr IMG_0940 by Ed Fleming, on Flickr IMG_0940 by Ed Fleming, on Flickr
Ed Fleming
RV-7- Nearly there!
Harare, Zimbabwe
01-05-2017, 01:15 PM
Flipped the Canoe!
Well, today was the biggest and most satisfying day in the project since unpacking the kit. I started riveting the "canoe" together around 8 weeks ago. In that time I have managed only 4 sessions, but 2 of those were marathons. It has been frustrating at times, but in the end it is well worth waiting for a highly competent riveting partner. Most of these rivets were shot by my buddy Kev whilst here on layover from his airline job. Kev worked on the hangar floor for a few years before becoming a pilot, so he knows his stuff. If we had to drill out one of his rivets it was probably my fault. My father in law Alistair helped with the final session and today we finally "flipped the canoe". What a moment IMG_0971 by Ed Fleming, on Flickr IMG_0972 by Ed Fleming, on Flickr IMG_0973 by Ed Fleming, on Flickr IMG_0976 by Ed Fleming, on Flickr IMG_0979 by Ed Fleming, on Flickr IMG_0980 by Ed Fleming, on Flickr IMG_0982 by Ed Fleming, on Flickr IMG_0984 by Ed Fleming, on Flickr
Ed Fleming
RV-7- Nearly there!
Harare, Zimbabwe
01-06-2017, 08:23 AM
It looks great! And it's a 7!!
01-07-2017, 07:40 AM
Nice job. In the second photo, is that a cracked flange behind the 4 bolts?
2016 Dues Paid!
01-08-2017, 10:22 PM
It comes like that
I can see why you would think that, but both of those steel weldments came like that. They are actually separate parts, welded nearer the front. The gap is quite narrow between them and the powder coating partially covers the gap, which then leaves a ragged edge when they are pulled apart slightly.
Ed Fleming
RV-7- Nearly there!
Harare, Zimbabwe
01-09-2017, 02:39 PM
Nice progress, Ed! An especially thorough job of sealing the firewall.
Yeah, that freaked me out when I saw those brackets on my QB fuselage. I had this terrible sinking feeling that I'd have to re-crate the fuse and send it back to Van's. Perfectly normal, as it turned out.
Doug
RV-9A "slider"
Tail number N427DK
Donation made for 2020
01-12-2017, 01:02 PM
Thanks Doug, almost 3 years and I'm just getting to the QB stage! Loved every minute though
Ed Fleming
RV-7- Nearly there!
Harare, Zimbabwe
04-03-2017, 12:48 PM
Aft deck
First job after flipping the canoe over is the aft deck. First I levelled the fuse longitudinally.
IMG_0992 by Ed Fleming, on Flickr
And Laterally
IMG_0995 by Ed Fleming, on Flickr
0.3 degrees out at the aft deck, doesn't seem like much.
IMG_0998 by Ed Fleming, on Flickr
I used ratcheting straps to remove the twist and drilled. I tried removing the twist by hand and clamping but it just wasn't going to happen. The straps held it nicely.
Also as you can see I could have done this with just the bubble level. Oh well, we like gadgets and numbers!
IMG_1000 by Ed Fleming, on Flickr
Here's another view showing the lower strap on the tail spring.
IMG_1001 by Ed Fleming, on Flickr
Ed Fleming
RV-7- Nearly there!
Harare, Zimbabwe
04-05-2017, 09:44 AM
Very nice work Sir!
Kentlik
RV-7A in progress
http://www.imdb.com/name/nm0527486/?
Private pilot, ASEL!
EAA 105 Chapter 7S3
Bi-annual financial contributor
"The credit belongs to the man who is actually in the arena..." Teddy Roosevelt
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
