Old 02-11-2014, 06:22 AM
Fearless's Avatar
Fearless Fearless is offline
Default Need contact info for Jim Auman (DAR)
Does anyone have the current contact info for Jim Auman (DAR)? The phone number that is listed on the EAA website for him under DAR's is no longer in service.
Mike
RV-9A Based K6I2
Flying - out of Phase 1
Building RV-12 with brother
Old 02-11-2014, 08:28 PM
RV6_flyer's Avatar
Got an email from Jim Auman after I emailed him.
He emailed me the following:
"Gary have Van's Airforce directory update with the current information found on the FAA Directory File that I am attaching.
The FAX number is not active.
The 630-886-0835 is very active.
I also am covering Tennessee on occasion. I continue to do WI, IL, IN, OH, and KY. Occasionally Expand to TN."
His contact info is current in the FAA Feb 03, 2014 DAR directory.
This is a Copy / Paste from page 20 under Illinois. I edited @ and . so that the SPAM bots do not pickup the email address.
Auman , James L
2900 E Pleasant St
Dekalb, IL 60115
Phone:
Fax:
Email:
(630)886-0835
(815)899-8861
captjim737<AT>gmail<DOT>com
Function 17, Limitation: Can only issue admendment/replacement for Special
Airworthiness Certificates. Amateur Built and Light Sport only. Mr. Auman will contact
the Vandalia MIDO before issuing any of the above airworthiness certificates.
Function 46, Limitation: None
Function 47, Limitation: None
Function 48, Limitation: None
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 02-12-2014, 06:49 AM
Fearless's Avatar
Default Thanks Gary
I sent you a PM before I saw your reply post so just ignore it - you already have the info I received from Jim.
Thanks for your help.
Mike
RV-9A Based K6I2
