Old 02-10-2014, 09:37 PM
MK77 MK77 is offline
Default Anti-splat oil separator with Superior IO-360
Just finished installing the Anti-Splat oil separator on my RV-7 with a Superior IO-360-B1A1 engine. I purchased the install kit and vacuum valve with the saddle. Parts looked great and the install kit came everything needed. My order shipped out the same day ordered.
The one issue had I believe is specific to the Superior engine. The oil return is set out a little bit from the accessory case and caused the 90 deg fitting to interfere with the engine mount. I used a low profile 90 deg NPT adapter couple to the included NPT to AN 90 deg fitting. A straight NPT to AN fitting would have probably worked better here but anyway, here's a picture:
The exhaust saddle made the vacuum valve the installation simple. Overall, other than the snag with the oil return it was a pretty easy install.
Matt K.
RV-7 Tip-up - Flying!
XP Superior IO-360 w/cold air sump, Catto 3 blade prop
Garmin G3X
CFI, CFII, MEI
Old 02-11-2014, 09:01 AM
JohnInReno's Avatar
JohnInReno JohnInReno is offline
I had the same problem on a Superior IO-320 and solved it by shortening the pipe thread on the 90 degree fitting. It helped to find someone with the complete set of dies.
John Morgensen
RV-9A N946PM 600+ hours since 2013
Nevada/Arizona
Old 02-11-2014, 09:54 AM
bullojm1's Avatar
bullojm1 bullojm1 is offline
Would someone mind posting more pictures of their Anti-splat oil separator in side-by-side RV's? I am interested to see where people mounted the separator on the firewall, and how they routed the tubes.
Thanks!
Mike Bullock
RV-7, Flying!
http://www.rvplane.com
EAA Technical Counselor
hydroguy2's Avatar
I was able to use a 45* fitting to miss the mount
Old 02-11-2014, 09:59 AM
hydroguy2's Avatar
Thanks!
Check this thread for some pics:
http://www.vansairforce.com/communit...i-splat&page=8
Old 02-11-2014, 10:11 AM
Maybe I'll try that seeing as my old man is a machinist and I know he has the NPT dies.
I'll look at using a 45° as well but it's pretty tight so I'm not sure that would even work.
Thanks!
Matt K.
Garmin G3X
CFI, CFII, MEI
Old 02-11-2014, 11:20 AM
paul mosher
Posts: n/a
Default Fitting
I see you have a aluminum fitting connected to a steel one.
Old 02-11-2014, 12:10 PM
airguy's Avatar
airguy airguy is offline
Thanks!
Here's mine (9A, right side of the firewall) before I got most of my FWF stuff added. Fits quite well there.
Old 02-14-2014, 11:09 AM
True. Not ideal, but that was the only fitting I could find that would allow it to fit.
Matt K.
Garmin G3X
CFI, CFII, MEI
Old 02-14-2014, 12:25 PM
sailvi767 sailvi767 is offline
We had the exact same issue on a ECI 360. The 45 degree fitting fit.
George
