02-10-2014, 11:36 AM
Wing Spar Bolts and Engine Mount Re-Torque
I am curious to hear from experience RV mechanics like Mel and Walt on the subject of re-torqueing spar bolts, both early laminated spars and current machined spars, and engine mount to firewall bolts.
What are others doing, if anything, and if so, at what intervals.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
02-10-2014, 03:25 PM
I check them on every condition inspection and I have found both spar and engine mount bolts (mount/airframe) under-torqued/loose on many aircraft.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
02-10-2014, 03:41 PM
Very interesting. Old spar, new spar??
Thanks Walt.
Interesting that most of the condition inspection check lists I have reviewed do not include checking these.
Bucker Jungmann
RV1 - Proud Pilot.
02-10-2014, 03:58 PM
Both
Originally Posted by JonJay
Thanks Walt.
I check all critical bolts with a wrench to ensure they are tight, looking at them don't cut it (pretty hard to tell if a bolt is loose or sheared by looking at it).
This includes but is not limited to all: engine controls, flight contols and primary structure (especially vert/horiz attach and wing spar), fuel/oil line fittings/B nuts etc..
I also check things like sump bolts, mag bolts, exhaust hanger bolts, exhaust/intake cylinder bolts, MLG attach/fairing attach, tail wheel attach nuts/bolts.
I also don't care if "torque seal" is there they can still be loose (and have been).
You get the idea.
That's also the reason I schedule a week for condition inspections, anyone that says they can do a good inspection in 1 or 2 days.... well I better leave that one alone before I get in trouble.
02-10-2014, 04:10 PM
Believe it or not; I have found loose bolts/nuts on initial airworthiness inspections that have torque seal on them.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
02-10-2014, 04:19 PM
Ditto - Specific to the Mount and Spar, this is how I discovered a couple bolts needing to be tightened. I chose to re-torque all of them, which revealed that a couple where slightly under torqued, even though they passed the "wrench" test.
I assume you do not put a torque wrench to each bolt at each CI or am I mistaken? I think there are some odd 60 AN3's in a 6's spar alone.
I am not trying to get carried away here, just want to know what the "pro's" do. I only have one RV to take care of.....
Bucker Jungmann
RV1 - Proud Pilot.
02-10-2014, 04:28 PM
Spar bolts
I am curious if these under torqued bolts were installed that way and then discovered or if they were properly torqued and found loose at a later inspection.
The spar bolts, when properly torqued using lock nuts should not be coming loose.
Chris m
RV-4 "Mr. Twister"
Pitts S1S "Mexican Red" sold and missed
Mr. Twister Airshows
Rocky Mountain Renegades
the mission... have fun.
02-10-2014, 04:40 PM
Chris m
Chris - mine did. They where torqued at one time, 100% positive. They where not "loose" but a few did need to be tightened. Don't ask me how a torqued bolt loses it's torque, but.....
Also, keep in mind most bolts in an RV are shear, not compression or tension. A slightly loose bolt is probably not going to do anything or be a concern in most of our applications. However.....
Bucker Jungmann
RV1 - Proud Pilot.
02-10-2014, 04:56 PM
I have a "calibrated" arm and use a wrench to check most things. Certain things I just get out the torque wrench (like exhaust studs) and torque them.
Chris m
Who knows but I suspect many were not torqued correctly from the start.
This may be true, but just like the recent nose gear bolt failure, a loose bolt will allow the pieces to start moving relative to each causing wear to the bolt, bolts holes etc, things start getting loose and so on.
