02-09-2014, 08:32 PM
Postlude: Declared an Emergency Today
To finish up the thread, "Declared an Emergency Today"...
Got the p-mags back from the shop, installed, and the plane ran up fine yesterday. Ferried it back home today, and *everything* worked as expected: prop gave the same minor surge on takeoff, speeds were back up, everything.
Quick summary of the original problem: With 8 hours on the 15W50 oil that replaced the 100 weight; and having just fueled the airplane; on a day that was perfect for carburetor ice; had a prop surge, declared an emergency, had a few power burbles on the way back to the airport I'd just taken off from, and I lost more than 20 knots of groundspeed with the MP and tach unchanged. After landing, the runup was fine.
But the next day, on runup, one p-mag was completely dead. Somebody else had had the same experience with a p-mag failure, also leading to an inflight power loss. My problem was a dying p-mag, and if I'd been more knowledgeable / more aware, I could have checked the mags in flight, restored full power (probably), and flown home.
By the way, the p-mags are a cinch to time. They have a manifold pressure sensor, and the way you time the mags is to turn the prop to top dead center (not 25 degrees before) and cinch 'em down tight. Turn on the master switch with the mags off and observe one color LED on the back of the mags; blow once and observe the LED color change to something else; blow again and observe the LEDs change to another color. You've just timed the mags.
Thanks to one and all for the thoughts, comments, and suggestions.
Ed
02-09-2014, 09:07 PM
Seems to me there are a lot more Pmag failures per capita than magneto failures (by ratio) than many people are prepared to admit to.
This is speculation on my part, but when you know someone who has had a dual Pmag failure recently in a RV7 with about 50-100 hours on it, and I read and remember a few on VAF, it makes me wonder.
I know some will read this and be saying I am EI bashing, because I have declared a definite preference in the past, but I am not. I am however running a flag up the pole.
Food for thought.
______________________________
David Brown
DYNON Authorised Dealer and Installer
The two best investments you can make, by any financial test, an EMS and APS!
02-09-2014, 09:13 PM
VAF Moderator / Line Boy
The problem with your observation, Dave, is that very few people come on and post "I had a perfectly normal flight today" - they only post about problems. And the truth is, P-Mags had more failures in their early models than the later ones. Many of the failures you are hearing about are with early models that just don't get flown very often and also haven't been upgraded.
I've had more Slick problems in the last eight years than I have had P-Mag failures. Does that statistically mean anything? Nope - statistically insignificant and anecdotal.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
02-10-2014, 06:39 AM
Ed
Just to state the obvious, the in flight prop surge is quite indicative of an ignition failure. Reduction in power output, rpm comes down, governor spools the prop back up to the requested rpm. Been there, done that many times, got the t-shirt and shorts stains.
Scott Card
CMW E-Lift
02-10-2014, 07:12 AM
Ignition failure
Usually an ignition failure results in a trivial power loss. This one resulted in a significant power loss and 20+ knots of speed. That's what was the fooler.
02-10-2014, 07:41 AM
Thanks for sharing this Ed. When a slick mag fails it exhibits different characteristics that a P-mag - it certainly did not seem obvious at the time, I have certainly learned something about this components failure mode.
So this begs the question a bit, was your P-Mag (s) an early model(s) and not have the updates? (Sorry, maybe I missed it)
Paul, I think you meant "very few people report . . "  It's ok, we get it.
Electronics components fail high or low, short or open. FMEA provides the opportunity to ensure failure modes are somewhat controlled. Do the later P-mags fail off, or safe, so that the timing does not wander (potentially) wildly and cause potential damage? How is the reader supposed to know what vintage, serial number etc the failed unit is unless it is reported along with the number of hours to failure. All we know is IT failed and draw conclusions on that basis.
Bill
RV-7
Lord Kelvin:
02-10-2014, 10:40 AM
Don't yet know the answer
But it is an open question that deserves public knowledge... Stand by!
02-10-2014, 06:57 PM
Paul, As usual I cant disagree with what you are saying, and in this case I agree, nobody reports a perfectly normal flight, however, I really do not see the relevance of perfectly normal flights.
The problem with my observation is that there does appear to be a large number of EI failures relative to the number in use compared to the old dinosaurs-magneto. And I am not just referring to the PMAG, so I am not singling out one brand.
As for the older units Vs Newer units, there may be some truth to that and it is pretty normal to expect that. However, where you are mistaken is the DUAL FAILURE that resulted in a dead stick landing recently was a set supplied on a new engine in 2013, and I am guessing but say early 2013, so they are in the 12-18moths ago range.
Anecdotal is hard to measure, and easy to scoff at, but that does not mean there is not a higher incidence. In my experience mags that have been serviced as per instructions, rarely give trouble. Sure old and under-maintained ones give grief, but you should not be surprised.
Food for thought....
David Brown
02-11-2014, 05:46 AM
Save the philosophy. Ask the manufacturer to state exactly what failed.
Dan Horton
RV-8 SS
Barrett IO-390
02-11-2014, 07:20 AM
4,900+ hours of experimental flying with 1 mag and 1 EI. Box score:
• 1 mag failure on the ground during run-up
• 3 EI failures in flight
I would never fly a homebuilt with dual EI's; my 14 will have one Bendix and one LSE.
'83 LongEZ - N888EZ 3,671 hours
'89 LimoEZ - N26EZ 686 hours (sold)
A couple of Glasairs and a Lancair 320...
Next: a RV14 need something to build
