02-09-2014, 06:52 PM
Motor Mount 0-320 (160HP) /0-360(180HP)
Lookin at purchasing a used kit complete with finish kit. I would like to use the 160HP engine in my build. Owner has stated that kit includes mount for 180HP. Are they the same or would I need to sell it an purchase another one. Or will Vans exchange mounts it good condition for a restocking fee?
Also... any difference in cowlings?
Thanks!
02-09-2014, 07:27 PM
The 320 mount is a bit longer, to compensate for the slightly lighter motor. Don't know for certain, but the 320 cowl *should* have smaller cooling inlets, too.
02-09-2014, 08:13 PM
different engine mount and cowl for the 320...
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
02-11-2014, 10:12 AM
Any way to get a quote on those? I have emailed Vans but no response yet.
02-11-2014, 10:47 AM
Thanks!
If it's a RV-6 kit, the drawing show the same mount for both engines.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
02-11-2014, 10:50 AM
Yes... Gil is correct, the 6 used the same on both.
Reiley
VAF# 671
Friend of the RV-1
02-11-2014, 10:56 AM
Is your engine a conical mt?
I know my 0320-b3b required a conical mount which may not be the same as what you have for 0-360. Good luck and have fun!
Jim Woolard C56
N9855J RV-6 Donated 2020
02-11-2014, 11:10 AM
0320/0360
I was told from Vans that the mounts are the
same on all models with the respect to the 0320
vs 0360. With the exception on the 7/7a, the mount is
2" shorter for the 0360.
Al Girard, Newport, RI
N339AG
RV-9
02-11-2014, 11:49 AM
Sorry for the bad info in my earlier post. I knew that the -7 had different mounts, & the -7 fuselage uses many parts from the -6 fuselage, so it never occurred to me that the -6 would be different.
Charlie
02-11-2014, 12:25 PM
OK thanks everyone. Just trying to find out the truth about it. Because if I can use his engine mount and cowling that was ordered with the intention of using the 0-360 (180HP) with my intentions of using a 0-320 (160HP) then it is a WIN WIN for both he and I. Except for the fact that I may want a JAMES COWL :-D
