  #41
Old 09-07-2014, 01:10 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
Originally Posted by flyinga View Post
I'm with Alan on this one; put switches in both places, or at least have an alternative method of disabling the autopilot.
And the alternative method can simply be a pullable breaker on the circuit that provides power to the servos.
Simply bypass all of the software and hardware in the loop.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 09-07-2014, 06:43 PM
Norman CYYJ Norman CYYJ is offline
All autopilots that I have worked on over the last fifty years have a master power switch to the entire system. You must have a way of turning them off that cannot fail in the event that it fails, whether it is on an aircraft, boat or ship.
Old 09-13-2014, 03:00 PM
truflite truflite is offline
Default A/P Disconnect
I have the GRT Sport in my 7A project with the GRT A/P servos. I have DPST momentary on switch on the panel. This switch when depressed will either engage or disengage the A/P. This system also has a disconnect only switch will be on the stick. This gives me the safety of having to reach to the panel to turn the A/P on so as to not accidently engage it at the stick. But I have the ability to disengage the A/P from either position with the stick switch being closer for an emergency disconnect.
David Nellis
7A slider finishing kit
2015 VAF dues paid
