  #21
Old 02-09-2014, 10:26 PM
AF_Alan's Avatar
AF_Alan AF_Alan is offline
Default Both
I put one on stick and another on panel w/in reach of thumb when hand on throttle. Easy to wire in parallel and use whichever is most comfortable at the time.
Good luck
Alan
RV-9A N984AW
Old 02-10-2014, 07:30 AM
OLDSAM OLDSAM is offline
Default Why not go all the way?
Why not install a multi-button grip, Infinity or similar, and put the ptt, trim, AP disc/CWS, fuel pump, flaps, landing light/wigwag, and anything else you want on it. You can then run your whole pre-landing checklist without removing your hand from the stick. You would have to do some rewiring, from the panel location to the base of the stick.
OldSam
RV7A, Empennage, Wings & Tanks complete
Fuse under way
Old 02-10-2014, 08:05 AM
Mel's Avatar
Mel Mel is offline
And don't forget, master, starter, ignition, radio volume, OnStar, and cruise control!
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 02-11-2014, 10:47 AM
seattleworm seattleworm is offline
Default Mine is on the panel
Since I like simplicity, I just use the one button stick grip, and put the A/P switch on the panel, close to the throttle control.
Shawn Li
RV-7-First Flight 5/27/2014
RV-10, Tailcone completed, wings in work
Old 02-11-2014, 12:05 PM
Pat Hatch's Avatar
Pat Hatch Pat Hatch is offline
This is one of those areas where personal preference is really the determining factor, but I would make a general point on the autopilot disconnect switch: long ago, I was taught to always have your hand on the stick (yoke) when disconnecting the autopilot, for obvious reasons (at least to me). One way to be sure is to have the disconnect on the stick--that's why I am a proponent.
Pat Hatch
RV-4 (Gone to RV heaven)
RV-6 (N44PH - Flying)
RV-7 (Sold)
RV-8 (Builder & Avionics Installer)
www.phaviation.com Trim Relay Boards/Flap Actuators
www.pathatch.com/blog (Photography)
Track Me
Old 02-11-2014, 12:20 PM
Default HOTAS
Exactly, Pat,
There is a practice used in some military flight programs called HOTAS, hands on throttle and stick. The idea is to keep your hands on the throttle and stick as much as possible, particularly during takeoff and landing, hence the concept of having much of the pre-landing checklist items on the grip, such as APD, landing light, trim, ptt, fuel pump, flaps, etc.
OldSam
Fuse under way
Old 02-11-2014, 12:24 PM
Sam Buchanan's Avatar
been here awhile
That is why my panel mounted switch works very nicely--left hand on stick, right hand on throttle, right index finger on switch.
Sam Buchanan
RV-6
Fokker D.VII replica
Old 02-12-2014, 07:12 AM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default Clarification
I'm am wiring my panel on the new 7. My AP disconnect will be on the grip as it was with my first 7. Also, there is no reason you can wire in 2 switches for the same purpose, one on the stick and one on the panel.
After reading the posts, I was a little confused about what the CWS actually accomplishes. I want to be able to disconnect quickly. After reading some of the posts I thought that the CWS would re-engage as soon as you let off the switch/button. I shot an email to Lucas at TT and got the following response.
"It serves both functions. If you press and hold it, the AP will go into CWS mode. Upon release the AP will re-engage. But if you just press and release the switch the AP will disengage. I hope that clears it up."
Cleared it up for me
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
Old 02-12-2014, 08:13 AM
Pat Hatch's Avatar
Which is yet another reason why I would make the case for having the CWS/disconnect switch on the stick. If you use the Control Wheel Steering function, then it would make sense that it should be on the "control wheel." Typically you would use the CWS function when on autopilot and you momentarily want to take control, such as to deviate around traffic, then give it back to the autopilot.
Also, I would argue that anytime you would encounter a situation that would require an immediate control input (such as a bird, etc.), it would probably be faster to have the disconnect on the stick. Just food for thought.
Pat Hatch
RV-7 (Sold)
Track Me
Old 02-12-2014, 08:43 AM
sailvi767 sailvi767 is online now
Unless I have a different version of the TT that is not correct. If you push and release the autopilot switch it disengages. No issue there. If you push and hold the button down it does the exact same thing. The autopilot disengages. The difference is that when you have held the button down the autopilot will reengage when the button is released. It never goes into a CWS mode. I am not sure why they even call it that. A CWS mode leaves the autopilot engaged and the autopilot and servos are still flying the aircraft. Inputs to the autopilot are made with the stick rather then the EFIS or control head. There is a vastly different feel to a aircraft using a CWS system when engaged and it requires a different control technique.
This is not a slam on the TT autopilot. Initially I did not really want the button on the stick. My partner wanted it there so I agreed. It turns out he is much smarter then me and I find both functions of the button very useful on the stick and would not switch back. I dodged a bird just last week with the button on the stick. Had it been on the panel as in our prior setup my only option would have been to duck. Both the disconnect and poor mans CWS have been getting far more use then I imagined.
George
