Old 02-07-2014, 07:24 PM
HeliCooper HeliCooper is offline
Default Hope I'm not the first to do this
So I dropped my die organizer. No big deal, got everything put back in its place....so I thought. I got all the way through my entire elevator sub structure before I realize I was using the AN3 male (which I always double check) with a 120 degree pop rivet female.
So the question to you all is what your suggestions are moving forward. Should I go back and redimple every hole? The current dimples accept the skins just fine but it is a little sloppier than it should be. I also dimpled the counter balance skins with the pop rivet female. Those I will have to redo for sure but I am not positive it is okay to dimple twice.
Long story short...just looking for a little guidance. I'd like to be able to get some work done over the weekend but don't want to proceed until I have a good answer.
Lesson also learned. Double check both male and female dies...
Old 02-07-2014, 07:42 PM
rvbuilder2002's Avatar
Jim, since you were using the correct male die, the dimple angle should still be about 100 deg., I don't think there should be any problem, as long as you feel that it formed the dimple well enough.
Scott McDaniels
Hubbard, Oregon
Old 02-07-2014, 08:38 PM
aerhed aerhed is offline
Redimpling is pretty fast because the existing dimples make lining up the dies quick.
Actual repeat offender.
Old 02-07-2014, 09:49 PM
If it is okay to redimple I will go back and do it. It won't take long. I just didn't know if I would do more damage then good by bending the aluminium twice.
Old 02-07-2014, 10:09 PM
It wont hurt anything, but I doubt it will even make a noticeable difference.
Scott McDaniels
Hubbard, Oregon
Old 02-07-2014, 10:16 PM
Thank you much!
