Old 02-07-2014, 11:51 AM
Steve Ashby's Avatar
Steve Ashby Steve Ashby is offline
Default Anybody out there want to pimp out their 21/32 drill bit?
Brother builders,
My building buddy, Sam Beale (Old Sam on the VAF net) and I are scratching our heads on this one. The plans tell us to drill out our nose gear brackets (U713C) to 21/32nds. A quick check with Vans told us that we really need to use that size hole, not the easier to produce 11/16ths.
For cryin our loud, who has a 21/32 drill bit? I feel certain that we will only drill out a grand total of 4 holes with such a tool. We are too cheap to spend $40+ for a paperweight that will generate 4 holes and then go into retirement.
Is there anyone out there who will rent/lend such an implement to these humble servants? We promise to deploy said bit to produce the aforesaid 4 holes and then send it back to you all polished up and smelling nice.
Thank you in advance for your consideration.
Steve & Sam
Steve Ashby
Stone Mountain, GA
N184RW (reserved)
RV-8A
YIO-360 180 hp Lycoming
Hartzell Blended Airfoil Prop
Engine Hung
Old 02-07-2014, 11:54 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Might try looking for an adjustable reamer--------or even a 21/32 piloted reamer.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 02-07-2014, 12:08 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Default $11.90 @ Sears
http://www.sears.com/drill-america-2...&blockType=G12
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 02-07-2014, 12:20 PM
TShort TShort is offline
Default or amazon (prime)
http://www.amazon.com/s/ref=nb_sb_no...%20drill%20bit
Several cheap options on Amazon ... esp if you are a prime member...
Thomas Short
KUMP - Indianapolis, IN / KAEJ - Buena Vista, CO
RV-10 N410TS bought / flying
RV-8 wings / fuse in progress ... still
1948 Cessna 170 N3949V
Old 02-07-2014, 01:14 PM
NYTOM NYTOM is offline
Default Got one.
Steve if you can't find one quick locally I'd be happy to mail mine down to you. I'm up in Upstate NY so if I mail it tomorrow you would probably would have it by Monday or Tuesday. If you get back to me right away I may be able to get it in the mail today. PM me if interested.
Tom Norwood
Classic "Short Tail 6A N822PM
TMX-O360. Phase 1
Old 02-07-2014, 02:50 PM
RONSIM's Avatar
RONSIM RONSIM is offline
Default Did mine today with a step drill
Yes, it is (slightly) oversize, but using the 616 washer as the "fit" template, the fit is close enough ---- hardest part is cutting the notch perfectly parallel, but everything fit great. Now, the hard part -- fitting the fairing to the brackets and installing the nutplates.
EDIT: -Just my luck! ----- got the brackets fittings just right, drilled out the existing brackets on my fairing ----- apparently the brackets are for newer (i.e. WIDER) fairings --- my existing fairing is about an inch or so too narrow and fiberglas just will not stretch that much. Oh, well, the rivets attaching the old brackets were starting to pull through and needed replacing --- just used cs screws, tinnermans and loc-nuts.
Back to flying!
RV-10 Co-built, maintained, flown (sold)
RV-8A Maintained and flown (Sold)
RV-6A Bought and Flying (N177RV), upgrades $$$
IO360, 180HP/CS, AFS 5600T, D10A, G650, G430, G327, ADS-B, VIZ385 AP
Very Happy Contributor
Comm, SMEL, CFII, A&P
Based at KCLW (Clearwater, FL)
Old 02-07-2014, 03:09 PM
Default Thanks for all of the help!
And a special thanks for the offer to ship me a loaner from NY. Sam and I decided to buy one of the cheapies from Amazon.
Steve Ashby
Stone Mountain, GA
N184RW (reserved)
RV-8A
Engine Hung
Old 02-07-2014, 03:10 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
my local ACE has a large supply of individual bits, fractional and numbered for about $3-5 each. you might check there.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
