Old 02-07-2014, 07:25 AM
DanBaier's Avatar
DanBaier DanBaier is offline
Default Transponder upgrade
I have a Garmin GTX 320A with a Garmin 430W installed. I think my easiest path to ADSB out is to install a mode S transponder. Has anyone with a 320 upgraded? If so, to what unit? (I assume that nothing is out there that is rack swappable.)
Dan
RV7A (N7101) - Flying 10/2008
CFI- SE/ME/Inst
A&P
KC2ZEL
Old 02-07-2014, 07:46 AM
Walt's Avatar
Walt Walt is offline
There is nothing available that is "plug n play" compatible, you will have to change the rack/wiring. I've installed a number of Trig TT31 units in customers aircraft and I also have one in my own aircraft and have been very happy with it. The Garmin 330ES is a nice unit as well but is much higher priced than the trig unit (the trig will also accept any data stream for position so you can use it with any GPS unlike the 330 at least until 2020).
The racks on the Trig and Garmin units are much longer than the 320A so you will have to cut a hole in your sub panel if one is not already there.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 02-07-2014, 08:35 AM
vic syracuse vic syracuse is offline
Super Moderator
Default TT31
I've in stalled a couple of the TT31 Trig units for the very same reasons, and they work very nicely.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
Old 02-07-2014, 09:22 AM
jclark jclark is offline
I have also assisted with ADS-B installations involving the Trig TT-31 *and* the TT-21/22. Also the Garmin 330ES to a lesser extent.
A couple of points.
1. If you had a Garmin 330, upgrading to the 330ES is probably your cheapest route. That and your 430W and should be "good to go". <I know of a 330 that is available.>
2. If you had had a KT-76 that died, you could plug in the TT-31 and use it as a basic transponder until you were ready to install the TRIG tray for the ADS-B.
3. If you have space constraints, the TT-21/22 can be attached as a REMOTE device for some EFIS systems *OR* can be installed with a 2 1/4" control head otherwise.
My TT-22 is currently being fed by my Garmin 496 (I had the GPS OUT wire easily available).
James E. Clark
Columbia, SC
RV6 Flying, RV6A Cowling
APRS
