Go Back   VAF Forums > Model Specific > RV-9/9A
  #11
Old 02-06-2014, 05:13 AM
Easy fix. Tap it!
Vlad, its a nut, not a cask.
Old 02-06-2014, 06:45 AM
turbo's Avatar
turbo turbo is offline
you cant be serious! whatever.
TURBO YES =VAF= Payed Jan2019
Ed D'Arcy
addicted pickle ball player
Old 02-06-2014, 07:23 AM
BillL BillL is offline
Holy Smooth Bore Batman!
I think that is one of those early prototype rivet heads with the self locking feature, before threads were discovered! Wow and someone has the matching rivet too! That is right up there with the engineer who designed, drew, and ordered a new camshaft for an I-6 engine that fired 1-2-3-4-5-6.
That stuff belongs in a museum!
Bill
RV-7
Lord Kelvin:
Old 02-06-2014, 08:52 AM
douglassmt douglassmt is offline
Default Low torque
You might have figured it out when you put a torque wrench on it.
Bryan Douglass
=VAF= 2020 dues paid
RV-10 N242BD
Old 02-06-2014, 09:56 AM
ty1295 ty1295 is offline
You sure that isn't a press fit nut? Just requires a slightly different yolk for your squeezer.
I have a matching bolt here at work somewhere for that nut also.
Jeff Scott
RV9A First Flight 9/30/19
Old 02-06-2014, 10:10 AM
Originally Posted by BillL View Post
....new camshaft for an I-6 engine that fired 1-2-3-4-5-6.
Last September, my 1918 Anzani engine actually did go to a museum. It was a 6-cylinder radial with a firing order of 1-2-3-4-5-6.
Yes, really - it was a twin-row 3.
Dave
RV-3B
http://www.vansairforce.com/communit...ghlight=Anzani
Old 02-06-2014, 10:19 AM
Low Pass's Avatar
Low Pass Low Pass is offline
A slip-fit, clearly!
Old 02-06-2014, 10:53 AM
Dave
RV-3B
That is interesting, and only possible due to the radial and master connecting rod configuration. I guess the joke was too much inside (crank, get it) for non-engine guys. Balance and dynamic forces would render an inline 6 unusable with that firing order.
I bet that radial sounded cool!
Bill
RV-7
Lord Kelvin:
Old 02-06-2014, 11:05 AM
Rootski Rootski is offline
You're gonna need a LOT of loctite for that one.
SEL +HP +Complex
Glider Instructor
No RV (Yet!) - drooling for a 4
RVators: Titanium Bolts, Screws, Nuts, and Washers at www.tiwings.com - a veteran-owned small business. PM me for any hardware needs!
VAF Advertiser
2014 Dues Paid - Active Duty, Paid Anyway. Thanks for the services!
Old 02-06-2014, 12:19 PM
Low Pass's Avatar
....Balance and dynamic forces would render an inline 6 unusable with that firing order.
Not so sure - with 1 on the front, it might go faster!!
