Old 02-05-2014, 10:39 AM
jimgreen jimgreen is offline
Default Baffle cracks with composite prop
On that lengthy SB thread Vic Syracuse mentions an apparent lack of baffle cracking on aircraft with composite props.
I got major cracks in the usual place after only 11 hours!
IO360 180hp
WW200RV prop - composite
Inboard edge of the oil cooler was braced to the case centre line.
Baffle kit was one of the newer "improved" versions.
I must be unlucky.
Jim Green
RV7 tip up
IO360 Whirlwind 200RV
Old 02-05-2014, 10:44 AM
YellowPeril's Avatar
YellowPeril YellowPeril is offline
I've had a few cracks appear on my baffles over the years. Nothing outrageous, or difficult to repair. There's a lot of thrashing about that goes on in there...
Nick "Hairball" Knobil
RV8 N80549 (First Flight 2003)
Aerosport O-360A1A, Dual LS CDIs, WW200C
Bowdoinham, Maine
Old 02-05-2014, 11:22 AM
vic syracuse vic syracuse is offline
Super Moderator
Default Baffling
I was referring to the baffling, and not the oil cooler mounts. They appear to have their own set of issues.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
Old 02-05-2014, 11:25 AM
Paul K Paul K is offline
Exact same story here Jim!
First showed up at about 30 hrs and became terminal at about 70 hrs. I also have the WW 200RV and new style baffles.
Paul K
West Michigan
2020 donation made, exempt but worth every dime!
Old 02-05-2014, 11:47 AM
johnfurey johnfurey is offline
210 hours with no problems so far.
RV7 Tipper
IO-360-M1B
WW200
John Furey, RV7. Ohio
Life's Short...Fly Often!
