02-04-2014, 06:05 PM
SB question for those out there
After receiving the new SB for the elevator, I was thinking what about the rudder... basically the same design... I like Mel's idea of adding a washer to those rod ends also... I am going to call Van's tomorrow and discuss this with them..
I will order the SB tomorrow for the elevator since I already have the other one on order... No cracks and I have been following the elevator thread on the forum for a while and have made an extra effort to look at those during my preflight.
Might as well do it all at once since everything has to come off the tail..
Doug... I am not bashing Van's, I am thankful for their watchful eye. It is just a shame just after finishing the plane and flying it for a couple of months that I am now going to have to do the SB to give peace of mind.
Jack
Smilin' Jack & Anita Hunt
N507H RV7, KJZP Jasper, GA
EAA690
APRS/ WB4JKY
Retired Corporate Pilot CFI-AI, MEL
CE500, LRJT, HS25, C650, SBJT, CL60
Hunt Aviation, LLC.
Pilot Service, IPC's Biennials.
Comm Glider
02-04-2014, 06:19 PM
Originally Posted by Smilin' Jack
... No cracks ......
Jack
Jack, I must be missing something in your post because you state you have no cracks. Why are you taking your recently completed aircraft out of service to do the SB fix. Inspection showed no cracks, Right?
Venice, Fl
02-04-2014, 06:29 PM
Thanks, but it was Walt's idea. I just agreed with it.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
02-04-2014, 10:16 PM
Mel and Walt. Can you please keep us all posted on the recommended washer that you would use. I have also read a thread a while back on a recommendation to install a washer on the attach bolts that hold the horizontal stab to fuselage.
Mark Malone, RV7
Wings complete, SB 14 complied with, canopy and cowling in progress, Up on the gear.
N442MM reserved
http://www.mykitlog.com/MikeMike
2020 Donation gladly paid..
02-04-2014, 10:24 PM
I plan on installing an AN960-616 or AN960-616L depending on how many threads are availalbe.
It is standard practice to use washers under the heads of bolts to increase beariing area and help distribute the load.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
02-05-2014, 03:40 AM
Gary,
I am planning on several long trips, and I carry the most valuable cargo in my life my family and friends, I also really enjoy doing acrobatics as that was some of the most fun I have done in my life. I have studied the SB's and although they will take some time to complete I figure about a week max, I am pretty current on my riveting still have the shop set up at the hanger so why not complete the SB.
Later if I want to sell the aircraft for any reason the buyer will know that all SB's have been complied with and they don't have to pay a mechanic several hundred dollars to complete it.
We have about 7 RV's at KJZP and most of the guys are going to do it.
The paint on my plane is still new enough and the painter stated he could use a airbrush and use a hot blend to match the existing paint if needed. Apparently this hot blend softens the existing paint so they blend together and practically make a shade difference hard to detect. I have single stage PPG on the tail.
Jack
EAA690
APRS/ WB4JKY
Hunt Aviation, LLC.
Comm Glider
02-05-2014, 04:29 AM
I am reconsidering the elevator SB since according to Vans:
Method of Compliance:
NOTE: If cracking has occurred at an outboard hinge position, install a doubler only at that position. If cracking is present at an inboard hinge position, doublers must be installed at both the inboard hinge points. This allows correct positioning of the attach point for the elevator horns.
That would mean to me that they seem to be pretty adamant about only complying if their are cracks... I think I will follow Walt's idea on the washers for the elevator. I just hope that the washers will not hide any cracks that could form.
Jack
EAA690
APRS/ WB4JKY
Hunt Aviation, LLC.
Comm Glider
02-05-2014, 07:46 AM
I would enjoy coming to watch some of the work. Drop me a PM please. Always looking for a reason to go fly.
George
"God does not deduct from one's time on earth that which is spent in the air."
02-07-2014, 06:49 AM
Wider AN970 Washers
Originally Posted by Walt
I plan on installing an AN960-616 or AN960-616L depending on how many threads are available.
It is standard practice to use washers under the heads of bolts to increase bearing area and help distribute the load.
I was also planning on using AN960 washers, but then this SB got me thinking . Why not use the wider 970 washers, they would provide quite a bit more bearing area. I don't have access to my tail kit right now, so I can't check. Would AN970-6 washers fit between the rivet heads? What are the opinions on using those washers instead?
RV-8
Empennage Passed Pre-close Inspection
Wings mostly done
Fuselage is "in the mail"
83126
Dash 8 day job is financing the RV-8
Donation till September 2021
02-07-2014, 07:09 AM
Please post the Vans view on installing washers.
I will order ... for the elevator since I already have the other one on order... No cracks...
Maybe put a hold on that? Didn't the revised SB explicitly state not to install the doubler on the elevator if there were no cracks?
Dan
RV7A (N7101) - Flying 10/2008
CFI- SE/ME/Inst
A&P
KC2ZEL
