Typically mags wear so slowly as to be unnoticeable. You only notice the change when you get the overhauled. A good mag from a reputable overhauler will typically have very little wrong with it at 500hrs, but if you do the interval, failure rate is miniscule too.
RV4 wing in Jig @ KPOC
RV7 emp built
