Old 02-13-2014, 06:17 PM
bret's Avatar
bret bret is offline
Originally Posted by rapid_ascent View Post
One thing that I've found that seems to help and I must admit I'm not an expert, is to use my lower pressure line to run the drill. The drill has less torque and is easier to control. It does of course drill slower too.
One of the best tools right behind the band saw and tungsten BB was the DeWALT 12V. Lithium ion drill. 2Lb and no compressor to run. Most used tool on the project!
Old 03-07-2014, 06:55 PM
spaceflightmeow's Avatar
spaceflightmeow spaceflightmeow is offline
Default Cleaveland removal tool?
Has anyone tried the Cleaveland rivet removal tool? Talking about this one:
http://www.cleavelandtool.com/Rivet-...ductinfo/RRT4/
I have the most trouble with round head rivets, using a split-point jobber bit. It just loooves to wander! Was thinking about using a plexiglass angle bit, but then I found this tool, which seems like an even more fool proof solution. Paying $50 for the apparent piece of mind that you will *never* screw up a rivet removal seems worth it. Any experience with it?
Into the blue again, after the money's gone
RV-7A
Empennage complete minus glass work.
Wings kit in progress.
Old 03-07-2014, 06:58 PM
jump4way jump4way is offline
I actually have one of those I'm going to put up for sale. I think I bought mine from Avery but it's the same concept. I'll sell it for $45 shipped in CONUS. It's very lightly used.
Old 03-07-2014, 10:24 PM
glenn654 glenn654 is offline
The trick for round head universal rivets is to grind/file a flat on top of the manu head to give you a stable surface to work from and use the normal procedure for rivet removal.
While it is easily written in practice getting access to the rivet head with the proper tool to make the flat is considerably harder.
YMMV
Glenn Wilkinson
_____________________________________________
RV-4 Sold
N654RV @ MLJ
RV-7 Coming Soon
N987RV Reserved
2015 Donation Gladly Paid
"Maintain Thy Airspeed, Lest the Earth Arise and Smite Thee"
Old 03-08-2014, 12:08 AM
JanRV6UK's Avatar
JanRV6UK JanRV6UK is offline
Never used ... (only enough to make my mind up that its useless ... )
I only use the drills .. the fit in my angle drill ! For drilling out rivets ... try a VERY pointy drill bit .. the sharper the angle the better ...
Jan
Slooow RV6, no hole, builder in UK
Paid up for 2015 ...
Old 03-08-2014, 04:03 AM
60av8tor 60av8tor is offline
Differing opinion. I can't see how drilling out a 470 could be any easier. A few caveats to the tool - 1) it is pretty large. If you have access to use the tool, drilling without it probably wouldn't be extremely difficult, although this tool prevents slipping off the head. 2). You cannot see the bit/head when using, so you must check often to monitor drill depth - not really a big deal.
Thanks for the note about the bits. I have the tool tucked away for its sporadic (knock wood) use, and never made the connection with the bits and my angle drill
Jon
Old 03-08-2014, 03:26 PM
JonJay's Avatar
JonJay JonJay is offline
I have the ATS version of this tool. I chuck it in my 90 deg. Die grinder which helps to keep the tool square to the work vs a drill motor but I use both depending. I have removed hundreds of rivets with it. I will break a bit from time to time if I am moving fast. I could not imagine doing what I do without it.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 03-08-2014, 04:01 PM
YellowJacket RV9 YellowJacket RV9 is offline
Several times I have used a metal cutting disc in my dremel to quickly grind off the factory head of a 470 rivet, when I don't have good access for a drill. If you go slow and careful,it's very easy to take off most of the material, and then just pop off the remaining sliver, and punch out the rivet. Can also be carefully done on the shop head.
Chris Johnson
RV-9A - Done(ish) 4/5/16! Flying 4/7/16
Old 03-08-2014, 07:29 PM
BillL BillL is offline
470 rivets were my nemesis, more than 70% were bad when driving. Now, after lots of removal practice, and learning how to drive them, now neither is a problem.
No extra tool needed for removal, just practice, or find someone with skill for training.
I do love tools though, I just bought a countersink dial indicator. That is a nice tool. I just hate checking each countersink with a rivet.
Edit 2/26/16 : Some time ago I saw a video of how quickly the alignment tool can be used to remove a 470 rivet. I bought one and it is fantastic! Very quick, very precise alignment and it has a depth stop for the drill point. Highly recommended if you will be removing many. I may be used on the shop head if they are nicely formed. Depth is not as accurate.
Bill
RV-7
Lord Kelvin:
Old 05-06-2014, 11:58 AM
Charles in SC Charles in SC is offline
I have one of those drill tools that works great for 470 rivets.
I have a tool that works great for pulling rivets out once the head has been drilled, it works even if the head has not been fully removed most of the time.
The tool I have is made for removing frets from a guitar.
Mine came from Stewart-MacDonald, stewmac.com. part #1637.
I do not know how to post a link. They also have a heavy cutter model #0619.
This can cut rivets, such as cutting the shop head off if needed.
RV 7
