Originally Posted by Canadian_JOY
Question here from a complete videography idiot... Does the new Garmin camera use this same type of image sensor? Is it as likely to experience this same type of jello/warping/whatever image distortion?
I'm no expert but the Garmin VIRB uses a CMOS sensor. The choice in video cameras seems to be between a CMOS sensor, with a rolling shutter and a CCD sensor with a global shutter. They both have their strengths and weaknesses. Both are capable of producing high quality digital movies.
Until recently, CCD were high priced and produced the best quality images. Apparently, in recent times CMOS sensors are catching up on quality and CCD's are dropping in price.
From what I've seen from cameras in this class - mainly Drift and GoPro cameras, the quality can be amazing. If you learn about your camera, I think Glen has pretty well shown that the jello shimmy can be avoided and Sam and others have shown how to avoid whacky looking propellers while using a camera with a CMOS sensor. Apparently CCD sensors have an issue with "smearing" and I don't know what causes it or how to avoid it.
My best guess, armed with the little knowledge I have so far is, exploring the strengths and limits of your equipment, so you can play off the strengths and avoid the weaknesses, is worth more than just buying a camera with different limitations.
You might see if you can borrow a camera (Drift, GoPro, or VIRB) and simulate an engine start of first flight and see what 'artifacts' you find in your video and then try and avoid the problem. My guess is on engine start, your prop is going to look strange unless you shoot it with a ND filter or do it in low light. If you shoot the first flight from the ground, I don't think you'll have many issues...but likely it will be time well spent testing it out.
