Old 02-12-2014, 11:33 AM
wrongway john wrongway john is offline
Quite a long thread, and have only went through half of it thus far. The SB states to ?Clean the area and remove any paint, overspray or primer that could hide a crack.? The pic that Van uses in the SB shows the crack without them removing the primer. Also noticed quite a few taking pics stating no cracks found, which didn?t bother to remove paint/primer either.
Old 02-12-2014, 01:49 PM
magiccarpet's Avatar
magiccarpet magiccarpet is offline
Default Step 13 Question
I don't understand why enlarging the forward top most holes of the flanges of HS-405 from #40 to #27 in step nr. 13 of the SB.
Those holes aren't anymore for any good after the SB fix, are they? I can't see from the drawings.
I rather don't want to enlarge them, 'cause they are already a tiny bit out of MED tolerance.
The most obvious reason I can imagine of, is to eliminate the 3/32 dimple around that holes. But why bother?
any ideas on that?
I probably should add that I haven't riveted the skin on the HS yet. Lucky me .So maybe that is why I don't understand the reason for step 13 yet.
Chris, RV-12 S/N 120832, HB-YSC
Facebook: http://www.facebook.com/magic.carpet.aviation
YouTube https://www.youtube.com/channel/UCLw...nv3vJiqAYoE-dg
=VAF= dues paid for 2020
Old 02-12-2014, 03:16 PM
rvbuilder2002's Avatar
Default There is a specific reason.
any ideas on that?
After the inboard spar flange gets trimmed, there is a gap between the rib and the skin at the location of this hole. If a rivet is installed as is, it can suck the skin inward and the rib outward. Undesirable for both.
Structurally there is very little benefit having them riveted together, so the hole gets enlarged to allow filling the skin hole with a rivet, but not attach it to the rib.
Scott McDaniels
Hubbard, Oregon
Old 02-12-2014, 06:05 PM
Geico266's Avatar
Geico266 Geico266 is offline
255 Hours
No cracks
No notches
Mild acro
Grass 40%
IO-360 195 HP
Constant speed
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 02-12-2014, 10:32 PM
Thumbs up
That makes perfect sense. Thanks a lot for your explanation
Old 02-13-2014, 06:09 AM
ao.frog ao.frog is offline
RV-7 290 hrs
Notches per plans
No cracks
75 % pavement
20 % grass
5 % snow-covered ice rwy's
Lots of std acro maneuvers (max +4)
Lots of formation
10 % at MTOW
Superior IO-360
MT C/S prop dynamically balanced
Moved with towbar on TW
Regards Alf Olav Frog / Norway
First RV-7 completed, (bought partly finished from a US-builder) 305 hrs per July 2014, SOLD
Second -7 had first flight Feb 25th 2014. 220 hrs pr July 2019. Life is good!
Old 02-13-2014, 07:54 AM
B Cunningham's Avatar
B Cunningham B Cunningham is offline
RV7 225 hours
No cracks
Builder # 71313
Notches per the plans dimensions
Mild acro
-5% grass
Always pushed around with the empennage. I'm changing that habit...
Ben Cunningham
RV7 N701VF
Bowman Field, Louisville, KY
Old 02-13-2014, 09:26 AM
tracy tracy is offline
Could you just use the cut out flange piece and use it for a spacer with a rivet?
Tracy Willingham
RV-8
Powered Paraglider
Pitts S2B- sold
Chattanooga, Tn
Dues Paid
Old 02-13-2014, 10:12 AM
Mark Burns's Avatar
Mark Burns Mark Burns is offline
You obviously haven't cut your flanges off yet :-)
They are not pretty. I needed a right angle dremmel.
And you're not really complying with the SB if you add your own twist.
Minor as it may be, it wouldn't fly in the certified world. No pun intended.
Mark
Mark Burns
Ruston, Louisiana
RV-7A N781CM 1,650+ hrs
FFI FL-24
A&P
Old 02-13-2014, 05:17 PM
bret's Avatar
bret bret is offline
Called Vans this morning inquiring about the repair kit. Apparently they sold out of the first batch pretty quick. Next week they should have the next batch ready to ship out she said. Just curious how many folk are doing the mod?
