  #11
Old 02-02-2014, 09:45 PM
paul330 paul330 is offline
I have added a sub-panel under the throttle panel and cut the tunnel cover just behind that. Added a flange and a couple of nut-plates to secure it.
I have modded the fuel system to remove the in-line filter and mounted an Andair gascolator on the left side inside the tunnel, which is effectively now the fuel filter. I can remove the bowl for cleaning by just lifting the rear section of the forward tunnel cover.
Paul
Mercy Air, White River FAWV
RV-10 ZU-IIZ - "Zeus"
Building Bearhawk Bravo - RV-18 not available
2019 Donation Made
