01-31-2014, 10:33 AM
Originally Posted by LeeM_2000
Another option is to buy the sheetmetal and use your skins as a template.
Oh, you mean the hard way? Without prepunched holes? Like they used to do on the 3/4/6?
01-31-2014, 10:40 AM
No, using an existing sheet with pre-punched holes as a template is way easier...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
01-31-2014, 11:57 AM
"Used to do?" Heck, we STILL do it that way.
Dave
RV-3B, now on the tanks
01-31-2014, 01:24 PM
You betcha...
Making new skins from scratch is easy when you have a flat template like that. Compare the prices of new stock to Van's plus shipping. Sometimes Van's is cheaper, other times Spruce is cheaper.
Katie Bosman
RV-3B sold, but flying!
Next project: ???
Builders gonna build...
01-31-2014, 10:08 PM
02-01-2014, 10:27 PM
All is not lost. if you scrap that skin you can use it later for other things.
I scrapped a skin and I have put that old skin to good use.
Paul Lips
Waxahachie, Tx
What Would EKG do?
Ernest K. Gann
N698K RV-4 Almost flying
02-02-2014, 09:49 AM
I missed with the deadblow hammer while dimpling one of my wing skins. If I remember the part from Van's was around $65 (2006) which wasn't much more than buying aluminum sheet. Shipping would have cost quite a bit so I just had them ship the new skin with the fuse kit.
RV 7 400 hours and counting
19 donation done
02-02-2014, 10:00 AM
Originally Posted by FredMagare
...would you have a tendency, while flying in the future, to feel uneasy if you were to use those skins in construction now? If yes, then replace them. The $$$ you spend now will be cheap insurance for your peace-of-mind later. Keep those skins as part of your trim bundle.
This is pretty much the decision maker for me. I'm on the fence for now, but long-term it might well bother me. But more importantly, my copilot was quite clear that she would be concerned about the skins.
In the grand scheme of the build, $200 is pocket change for peace of mind. I guess I'll have no shortage of scrap material now...
Philip
-8 fuselage in progress (remember when I thought the wing kit had a lot of parts? HAHAHAHAHA)
http://rv.squawk1200.net
02-02-2014, 10:10 AM
Van's Confirmed 10% Rule
I had some pretty serious surface corrosion spots on my wing skins when I bought a second hand kit. I emailed Vans and they said I could remove up to 10% of the thickness. An hour with scotchbrite, sandpaper and a can of primer and it was fixed. I did check the "deep" spots with a micrometer. Despite my fears, I had only removed 5-6% on the worst spots.
I was lucky enough that the corrosion started under the blue vinyl near the edges so I could easily measure. I can't tell from your pictures if it's near an edge or not.
RV-8
Empennage Passed Pre-close Inspection
Wings mostly done
Fuselage is "in the mail"
83126
Dash 8 day job is financing the RV-8
Donation till September 2021
02-02-2014, 10:22 AM
It's not...pretty much in the middle of the skins. The pictures aren't really great, but I made this thread as more of a lamentation of my stupidity than a serious inquiry about whether the skins were salvageable.
Your corrosion repair makes me even more convinced that I should get more skins; if you took off 5% with that, I suspect I'd easily approach 10% sanding these out. The scratches are pretty impressively deep.
Philip
