Old 09-14-2006, 12:48 PM
Steve Sampson Steve Sampson is offline
Default How to set up the fiberglass tips?
I would welcome a bit of advice.
At the moment my wings are in a wing stand. If I set and lock the aileron in the neutral position I could install the tip by aligning the trailing edges.
My question is would this be a mistake, and it better to wait until the wings are on for a trial fit, set up the flaps, ailerons and then do the tips? Would I end up with better alignement of everything?
Theory sais the first route should work just fine, but what about practice.......? I wonder if compromises are needed to get alignement.
Steve
G-IKON Build log here , or Index to blog here.
RV4 #4478 - Flying since 16th June '08. First flight video here.
Circuits at my 1000' strip.
Old 09-14-2006, 12:59 PM
szicree szicree is offline
I'd wait, just in case things don't go as expected with wing mating and rigging. Also, the top surface of the tip (most visible) is a lot easier to work on when on the installed wing.
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
Old 09-15-2006, 11:45 AM
Thanks for the advice Steve. I have decided to hold off.
Cheers!
Steve
Old 09-15-2006, 12:31 PM
William Slaughter's Avatar
William Slaughter William Slaughter is offline
I did mine wingtips on the workbench with the airleron locked into the neutral position. The way I'm reading my instructions and plans (-8) the aileron in neutral position is the reference upon which to align both the tip and the flap. Sure hope that's right, cause I don't want to cut open the trailing edge of that tip again!
William Slaughter
Houston, TX
RV-8QB
Old 09-15-2006, 12:34 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Steve,
Just as an additional datapoint, I did my wingtips in the wing stand. I set the ailerons up per the alignment holes and locked them in this position. I then mounted the tips to match the ailerons (from all accounts, I was one of the few people who's tips aligned perfectly, right out of the box), and then set up the flaps when the wings were mounted to the fuselage at the airport. This minimized the work I had to carry to the hangar (tips probably took a few evenings), and I found it pretty easy to work with the wings in the stands.
Steve Z's recomendation sure works too....
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
