Old 01-28-2014, 10:37 AM
s10sakota's Avatar
s10sakota s10sakota is offline
Default Pitot/Static tubing length?
Hi All,
I only have about 4 feet of tubing left from Vans to make my pitot and static lines in the wing. So obviously I need to order more.
Once I run the lines in the wing, how much extra should I leave to stick out of the root rib of the wing? Do I need enough to go all the way to the panel, or do I install a separate line in the fuselage and then connect them out side the fuse by the wing root?
Thanks!
Mark Pensenstadler
1962 Piper Cherokee 160
2003 RANS S-10
2011 RANS S-6S
2011 Vans RV-7
2015 Zenith Cruzer
1962 Mooney M20C
2019 KITFOX Super Sport
Old 01-28-2014, 11:08 AM
rleffler's Avatar
rleffler rleffler is offline
Originally Posted by s10sakota View Post
Hi All,
Thanks!
Not knowing your panel design, it's hard to give a definitive answer.
In my RV-10, I have to take the static line to five devices on the panel. (3 EFIS, 1 AP, & 1 Alternate Static Port) and the pitot line to all but the alternate static port. The pitot line in the wing is aluminum per plans, but in the wing root I transitioned to a nylon like tubing.
The push on connectors that SteinAir sells also do a good job at tranistioning between materials. With the variety of connectors and the fact that it's easier to install than aluminum lines, it may help solve your
dilemma.
bob
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 01-28-2014, 01:20 PM
wirejock's Avatar
wirejock wirejock is offline
Default Safeair
Get one of these.
http://www.safeair1.com/averytools/p...lumbingkit.php
I haven't installed mine yet but from reading other posts, most leave the excess spooled at the wing root till it's time to mate wings and route lines. Guess I'll find out.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 01-28-2014, 03:26 PM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
Originally Posted by wirejock View Post
Get one of these.
Yup.
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
