Hi there
I've decided to tick off one of the entries on my bucket list later this year and fly from New Zealand to Australia (via Norfolk and Lord Howe Islands). My RV-6 (with 180Hp Mattituck O-360) has sufficient endurance with a brisk tail wind or no wind to fly the three sectors that range from 320 - 485nm. However, there's not enough safe endurance for my liking particularly if I strike head winds that prove stronger than forecast.
For flight planning purposes I use 35 litres/hr; my actual usage over the life of the aircraft is 31 litres/hour; I can get it down to 28 litres/hr when cruising at 6000 - 8000'. To provide me with an additional hour of fuel I plan to install a 40 litre Little Buddy portable fuel bladder from Turtlepac (see
http://www.turtlepac.com/en/products...l-bladder.html). My plan is this:
The Little Buddy will be strapped to the passenger seat. It's designed to take up the shape of the seat with the fuel outlet positioned at the lowest point where the seat cushion meets the backrest.
The fuel hose will be connected to the centre mounted fuel selector via a fuel tap and drip-less fuel connector. This will allow me to remove the Little Buddy for re-fueling and when not in use.
My fuel selector has Off, Left, Right and an empty position at 6 o'clock. The empty position appears to be serviced by a port that's not connected. The Little Buddy will be connected to that. I presume the fuel selector was Vans supplied (I didn't build my aircraft).
I don't see the need for a fuel pump. As the seat is higher than the main tanks I believe fuel will be gravity fed and the engine pump and auxiliary electric fuel pump will be able to source fuel from the Little Buddy.
Takeoff and landing will be performed using a main tank. The Little Buddy will be used in cruise and when there's sufficient height to completely drain the bladder and let the engine stop.
How does this plan sound? Has anyone had experience with a similar fuel arrangement? Please let me know if I haven't thought of anything as I appreciate any advice on this important consideration for my trip.
