Originally Posted by airportkid
1. How come there's no noise from the unshielded wires running from the switch to the filters?
Electronics have gotten much better at rejecting outside interference
2. Since there's no noise from that source, could I run shielded P-Leads from the mags to a firewall terminal block, grounding the shielding at the firewall, and leaving well enough alone from the terminal block back to the switch?
There is noise, it's just being rejected by the existing radios. I use the shield as the mag ground so for me, a single uninterrupted shielded wire to the mag switch is best
3. Or maybe NOT ground the shielding, since it's already grounded at the magneto end. Google perusal has revealed that it's apparently not a good idea to ground both ends of the shielding - but I can't find any good explanation for why not. The portion of wire running from a filter to the mag has its shielding securely grounded at both ends, so this injunction seems inconsistent.
Old rule of thumb, gnd both sides to keep noise in, gnd one side to keep noise out. In this case, gnd both. Usually you only need to ground one side on audio lines (like the mic) as grounding both sides on those connections can cause ground loops (noise) in the audio system.
4. What's best: buying new filters for $150 and restoring the existing installation to what it was before? Or biting the contortionist bullet and running unfiltered but fully shielded P-Leads from the switch to the mag? Or going whole hog and replacing not just the filters but also the switch to filter wires shielded - and which end (or both) of the shielding should get attached to ground?
Is this a certified aircraft? Follow the manual and see if there is a problem after the installation is done correctly.
