Old 01-23-2014, 11:48 AM
Gash's Avatar
Gash Gash is offline
Default Camguard Tech Director Tells Why Not To Use 15W-50
I sent an email this week to Ed Kollin at Camguard asking his opinion of Aeroshell 15W-50, as I had heard some conflicting opinions. I asked him to provide some facts to help me decide what to use. He was kind enough to reply with the following email. I am copying it here for everyone--I hope you find it useful as well:
Hello Karl,
I do not like or recommend either of the two semi-synthetic oils that are
available, Aeroshell 15W-50 or Exxon Elite. Both contain PAO synthetic
basestock which in my opinion, is the worst possible basestock for use in
aircraft (but great for cars). Aircraft engines contaminate their oil with a
lot of blow-by fuel. PAO is horrible in dealing with contamination and
this lead to greater varnish and carbon deposits throughout the engine.
The Aeroshell 15W-50 and Plus oils also contain a triphenyl phosphate
anti-scuff that decomposes and attacks seals in the engine. Camguard
protects seals from this chemical attack.
The Elite (which I did the initial research on when I worked at Exxon
Research) contains a multi-functional (dispersant) viscosity modifier which
holds water and forms a soft brown sludge in cool running aircraft.
I recommend Phillips 20W-50 or Aeroshell W100 oils. And of course with
Camguard as the additive package to prevent rust and deposits, reduce wear
and condition seals.
Regards,
Ed
Edward Kollin
Technical Director
Aircraft Specialties Lubricants
Karl, Goodyear, Arizona (KGYR) ATP, CFII
RV-14A, Flying
Extra 330LX, Flying
RV-8, Sold
RV-7, Sold
Bearhawk 4-Place, Sold
=VAF= donor 2020
Old 01-23-2014, 12:51 PM
CharlieWaffles's Avatar
CharlieWaffles CharlieWaffles is offline
Good to know. I just came out of Phase 1 and went with Aeroshell 15W-50. What process would I have to use to switch over to the Phillips if I wanted to? Can I simply do it during the next oil change or is there some compatibility issues?
CharlieWaffles - But you can call me "Mark"
RV-10
N928MT
Flying - AKA Still Tinkering
Build Project Site
Old 01-23-2014, 12:56 PM
TShort TShort is offline
Great ... I've been using 15w50 + Camguard in the skyhawk and the 170 ... I've got about 8 cases sitting in the hangar from the OSH Aeroshell discount!
Thomas Short
KUMP - Indianapolis, IN / KAEJ - Buena Vista, CO
RV-10 N410TS bought / flying
RV-8 wings / fuse in progress ... still
1948 Cessna 170 N3949V
Old 01-23-2014, 01:17 PM
n761tj n761tj is offline
Drain dirty oil.
Change filter.
Add Phillips 20W-50
Add 5% Camguard.
Start engine.
Stop engine.
Check for leaks.
If no leaks, go fly.
Ed
Old 01-23-2014, 01:30 PM
F1R F1R is offline
I have an 0-320 that has well over 3500 hours since new. I have personally put the most recent 1750 hours on it and have only used 15-50 aeroshell. I still get about 20 hours before I need to add a quart and that takes me to the next oil change.
The engine was run hard in a flight training operation in a C-177 for the first 2000 hours. Then it went into a homebuilt on condition. I pre heat for about 30 minutes with a silicone bonded oil pan heater pad if it is below freezing. I have a oil cooler restrictor to keep oil temps above 185 F in the winter.
Not disputing the thread post but I am happy with multigrade.
Old 01-23-2014, 01:47 PM
rocketbob's Avatar
My experience also parallels the observations here, if you want a clean on the inside engine run X/C.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 01-23-2014, 01:49 PM
There are a great many people that have had success using Aeroshell 15W-50. However, many people had success using Mobil Av1 synthetic (an all PAO formulation) and we know how well that worked out, Mobil paid for a lot of engines. Proportionately, and by far, I have seen more problems with AS 15W-50 than the straight weight AS oils (or Phillips).
If you are happy with AS 15W-50 then keep using it. I am merely reporting my findings over 25 years of working in the field, testing and formulating lubricant products.
Ed
Old 01-23-2014, 02:46 PM
Gash's Avatar
I didn't know that N761tj was *THE* Ed Kollin of Camguard fame! Thanks again for your help in clarifying the issues with 15W-50.
RV-14A, Flying
Extra 330LX, Flying
RV-8, Sold
RV-7, Sold
=VAF= donor 2020
Old 01-23-2014, 03:59 PM
131RB 131RB is offline
Like you I have run nothing but AS 15W50 and had nothing but good luck. I have torn down several engines that use AS 15W50 with no significant wear, or sludge after TBO. I choose to pay the extra for the Aero Shell for this reason. I am sure the other oils are fine as well but I have no experience with them and go with what I know.
I would be cautious about being scared off by the original post.
Ryan
Old 01-23-2014, 06:42 PM
JonJay's Avatar
JonJay JonJay is offline
Ill take it!
2300 hours on my 0320 (never even been topped) and 550 hours on the IO360.
What I didn't know hasn't seemed to hurt me.
I appreciate the science and the experienced observations. However, your best protection is to fly often, .... and fly well.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
