Old 01-23-2014, 10:01 AM
Sid Lambert Sid Lambert is offline
Default Paint on starter ring?
My starter ring / flywheel had a small amount of corrosion where it met the prop flange. After cleaning it I put a light coat of prime and paint on it and then thought that maybe wasn't a good idea.
While I can't find anything that says not to do it... I assume that it could potentially cause the prop bolts to loosen. Can anyone confirm that this is a no-no?
Sid Lambert
RV-7 Sold
RV-4 - Flying - O-320 Fixed Pitch - Red over Yellow
