Old 09-13-2006, 12:01 PM
captainron's Avatar
captainron captainron is offline
Default Cutting to Van's dimensions
Since I just got my QB-7 wings and fuselage last week, I would like to finish the wings first as Vans recommends. However, I would like to make alot of the builder-fabricated parts for the wings and fuselage at one time so I can deal with the alodining and priming at one time.
My question: Can I just cut things like aileron push-rod tubes per Van's blueprints, or are there things that have to be measured (other than fuel lines) with wings, etc. fitted?
Ron Leach
RV-7 N713CM reserved VAF # 603
Cincinnati
__________________________________________
"Wish I didn't know now what I didn't know then".
.....Bob Seger
Old 09-13-2006, 12:13 PM
Jamie's Avatar
Jamie Jamie is offline
Almost all of the measurements are good starting points. The pushrods are adjustable because you have some thread to play with on each end. Doing large sessions of parts fabrication is definately a time saver, IMHO.
Not a primer war here, but why are you going to alodine the parts on your QB? Seems like a waste of time/energy/money/health since your QB is not alodined.
Old 09-14-2006, 11:09 PM
RudiGreyling's Avatar
RudiGreyling RudiGreyling is offline
Most of the things so far has been OK if cut to Van's sizes, but the aileron push rods on my RV7 is the one thing that needs 3/8" more in my opinion. Do a search it was discussed here somewhere.
Rudi Greyling, South Africa, RV 'ZULU 7' Flying & RV 'ZULU 10' Flying
"Science, freedom, beauty, adventure...what more could you ask of life? Aviation offers it all" - Charles A. Lindbergh
