01-20-2014, 11:10 AM
RV Building Hands
Just wrestled my first fuel tank into clecos. Blood, sweat, and tears!
http://i39.tinypic.com/2u4sv3o.jpg
RV-8
Empennage complete (except tips)
Wings in the works
Supposed to be exempt, but I appreciate this site too much to not pay.
01-20-2014, 12:27 PM
tank
Ouch. What method did you use? Did you have help?
There are a few good tips posted. I preferred the one where you place the skin on a foam pad and push the rib into position. I found it easier to cleco the bottom first then coax the top using a tiny punch as a drift pin.
I do remember the first assembly was the worst. They seemed to go together easier the second time.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
01-20-2014, 02:29 PM
The "bleed as you go" method,,,,,,,sorry carry on
Bird
Bird
rv8 entire airframe at airport now, painting done, intersection and gear upper and lower fairings done, maybe order engine around first of year or before the next rate increase.
"to fly is a privilege that I am so thankful to God for"
http://www.mykitlog.com/tcb328/
01-20-2014, 02:59 PM
Make sure and get pics your arm after you rivet the skins on the wings.
01-20-2014, 06:37 PM
I'll try the bottom first next time. I put a few clecos in the top forward end first. I couldn't pull the bottom forward end into place, so I started from the aft end on the bottom and leap-frogged clecos until I got them into the front end then back filled. I didn't use the foam pad because I was on a carpeted floor rolling around with it. Thanks for the tips! No pain no gain!
RV-8
Wings in the works
01-20-2014, 07:47 PM
I also found it much easier to cleco the bottom holes (forward edge) first and work my way across and up (aft) using a couple tapered metal scribes to help line up the holes as I went along.
David C.
Howell, MI
