01-20-2014, 06:28 AM
How many circuit breakers for RV-7A?
I will start my panel and eletric system, evev togh my kit has not arrived yet I think I can get a alluminio panel cut and start work on that just to save time, system as follows
GARMIN G3X single unit with engine eis(all engine info here no gauges)
GARMIN VHF GTR 225
GARMIN GTX 327 TRANSPONDER
IPAD
AERA 500 PORTABLE GPS ATACHED TO PANEL
D1 DYNON POCKET EFIS ATCHADED TO PANNEL
AND 1 12V OUTLET
NAV LIGHTS
LANDING LIGHT
QUESTION IS how many CB,S do I need and wich amps?
thanks in advance
Guilherme Plassmann (Brazil)
RV7A (Mr Flame) slow kit S/N 74285 Finished 04/14/15😀😀😀😀flying
G3X
Superior IO360
Sterba prop
TSFlightlines hoses
LR30,PRM1,C560,C510S,HS125,B350 FAA/ANAC Pilot
Donation made 2016
01-20-2014, 12:49 PM
Breakers vs Fuses
IMO, first thing you or any builder should do with the electrical system is read Knuckolls's book which can be obtained here.
http://www.aeroelectric.com/Catalog/pub/pub.html
He is the guru many of us have used to wire our aircraft. After reading it you might toss the idea of circuit breakers. He recommends fuse blocks which are way lighter, way cheaper, take up much less panel space, etc...
Some like the looks of "acres of breakers", not me. Nomex on...
Just sayin'
Jerry
01-20-2014, 01:17 PM
I would agree with Jerry. Make a list of what each component draws and what the recommended breaker is per it's manual. Then think about what is flight critical and what would happen if multiple things go out. Also, the wire is sized for breaker size not load, so think about that too. Stein recommends a minimum size wire regardless of amps just due to environmental hazards like chafing and such. Some avionics have two power inputs each with a separate breaker. BTW - Don't let this list scare you for the apparent total amperages. That is a separate subject :-)
SteinAir did my panel wiring and selected the breakers, but I had some idea of it before starting. What little I have sized and done to install, I conclude it pays to either become knowledgable and understand each element or enlist expert (singular) to make a complete wiring diagram including breakers. Look at the Garmin experimental website and my panel is pictured there. N266WL is on on the panel. There are several very good panels there to learn from.
I have several things that use automotive style blade fuses that are not flight critical, but can be reached easily once on the ground. Like heated seats, trim, baggage compartment light etc. I don't regret having my panel built, as it was bench tested and I know it works together.
Good luck with your panel planning. It is time well spent. Also, once completed, I wish I had though more about the physical placement of wiring runs and hardware. You may want to do this as it would have saved me a lot of time.
Bill
RV-7
Lord Kelvin:
01-20-2014, 01:56 PM
Senior Curmudgeon
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
01-20-2014, 06:09 PM
Moderator, Asst. Line Boy
How many breakers?
For me? Zero. Vertical Power VP-X, my friend.
Scroll
Catch her on YouTube's "Because I Fly!" channel
Exemption waived.
Proud and grateful 2020 -=VAF=- Contributor
01-20-2014, 06:24 PM
On my RV9 I have nine breakers. Seriously. Guess how much you need on your 7
01-20-2014, 07:45 PM
I have a few critical to flight. Ask yourself the question: If it trips in flight, do I really need to reset it?
All are pullable
Avionics master
flaps
Trim Switchable
Plasma ignition
alternator field
Auto Pilot
SD20 field
Two spares (I have no idea why)
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
01-20-2014, 10:56 PM
I've never understood the obsession with needing to reset circuit breakers. A number of possible inflight emergencies don't faze me too much. But inflight fire does.
I prefer them especially for high demand items not so they can be reset, but because you can easily locate and pull them to isolate power to that entire circuit - something which I've had several colleagues on certified aircraft need to do when things have started producing smoke which wasn't called for!
Mike
Down Under
01-21-2014, 12:24 AM
Sometimes you want to "pull" a breaker such as when doing maintenance/troubleshooting. You may want to pull the starter's breaker for safety when you have the main buss powered for testing/troubleshooting.
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
01-21-2014, 04:32 AM
Thanks guys
G3X
Superior IO360
Sterba prop
TSFlightlines hoses
Donation made 2016
